Question about GE WWSE5240D Top Load Washer
Actual model is WWA3650SALWH
Im sure the help would be the same for this problem. This washing machine fills with water but it will not agitate or spin (extract). I pulled back cover off and the motor is not moving, its not a belt problem,or the door lid switch. I checked to see if motor is getting power, but it doesn,t seem that it is getting power. THe timer seems to work it moves all the way around the dial when left on. The motor just wont work.Any help would be greatly appreciated.
  • czq8 Jun 28, 2008
    I have the same problem with my GE washer (GJXRP080B2WW). We started the washer before going out and when we came back home. The cycle finished and the cloths were clean but all wet! I then tried again and it did fill water and drain but didn't agitate or spin. I checked the lid switcher, the timer and the agitator which are fine. However, the motor belt doesn't move and it seems the motor doesn't work when power was on. There are a lot of wires connected to the motor and I don't know which one to check to be sure power goes to the motor. Could you please help me? Thanks.
    BTW, I didn't find any Reset button or the start capacity...
I got this straight from the GE service people. If you have the model that has the magnetic strip sensor under the lid (to signify if the lid is closed or not) and not the pin kind...try this:
1. unplug the washer for about ten minutes, then plug back in.
2. open and close the lid five times.
Seriously, this worked for me and I was having the same problem (the washer would fill but wouldn't agitate or spin). I guess this combination resets the electronics within the washer.
Hope this helps!
Posted on Oct 16, 2007
    Novelist:
  • 114 Answers
JUST A QUICK SUGGESTION FOR YOU ... ON MOST WASHER MOTORS THERE IS A SMALL RESET BUTTON ON THE MOTOR ITSELF. TRY RESETING IT ... IF IT RESETS AND POPS RIGHT BACK OUT OR IS JUST FLOATING THE MOTOR IS MORE THAN LIKELY BAD OR ... YOU MAY ALSO HAVE A CAPACITOR START MOTOR. THE CAPACITOR IS UNDER A COVER ON THE MOTOR ITSELF THAT CAN BURN-OUT OR GO "OPEN CIRCUIT". THEY ARE REPLACEABLE. IT SEEMS YOU HAVE CHECKED ALL THE OTHER CULPRITS I USUALLY SUGGEST. I HOPE I COULD HELP OUT.
Posted on May 02, 2007
SOURCE:
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Agitator problem
POST MODEL NUMBER PLEASE
Apr 27, 2009 | Washing Machines
Will not move to the next cycle.
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Old model rca washer machine...will not agitate/wash the clothes,does spin.
    If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
    Sep 29, 2008 | Washing Machines
    Washing machine fills, but won't agitate
    maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
    Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
    GE WWSE5240D Top Load Washer Logo
    257 people viewed this question
    Top GE Washing Machines Experts
    Marvin
    Marvin
    jimorris77
    Gerry Harvey
    Gerry Harvey
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
