Question about Hotpoint TDC32 Electric Dryer
How to fit a new belt to a hotpoint condenser dryer TDC 32
Belt had snapped have bought new belt and unsure how to fit help!!
  • Hotpoint Master
  • 3,463 Answers
My advice to u would be to call an engineer to fix it, as it it involves a complete strip down, and is not an easy job to undertake unless u are prepared to spend a lot of time and effort, I speak from personal experience, so I know what I am talking about.
But again if u think u can do it then good luck, but don't say I didn't warn you!!!!.
Plz rate my suggestion.
Thanks
Posted on Dec 31, 2008
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
We have a hotpoint tdc 60 tumble dryer drum will not go round belt is still fitted and heater works any help would be apprecited
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2010 | Hotpoint Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Hiya could you help me please. do you have a fitting diagram for a drive belt on a hotpoint dryer deluxe 9305. as i am unsure how it goes through the pulley. thank you
Check out this page and see if any of them look like yours.
http://www.applianceaid.com/images/threadbelt2.jpg
Sep 07, 2009 | Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
Snapped door lock on hotpoint washer/dryer
What you need is a new door latch assy. To fit, remove all screws that hold the 2 halves of the door together, and prize the 2 halves apart, be careful the door glass does not fall to the floor and break.
Fit the new door latch, and reassemble door.
That should solve your problem.
The part is relatively inexpensive.
If you can;t obtain the part locally,then try:
www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Creda t601cw condenser dryer
hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Jun 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint TDC32 Electric Dryer Logo
196 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
