Question about Aprilaire 550 Humidifier
Aprilaire 560 does not work. No clicks
There are no clicks when I turn the humidistat dial while the furnace fan is running. Water flows into selonoid but not out of it. Cleaned all the mineral build up. Still no flow.
Last summer we had to replace the circuit board on the furnace. May be the technician did not hook the selonoid right. There are 2 wires that come out of the selonoid (Red and Orange). Red is connected to the HUM on the circuit board. The Orange is hanging free. Is that right?
What might be wrong here?
  • 3 Answers
I just solved a problem with mine today.  One of my low voltage power wires to the humidity control had a bad connection.  I reconnected it and I could again hear the solenoid valve clicking as I adjusted the dial control.
I found the problem with a voltmeter:  there was voltage at the power terminals on the humidity control terminal board, but there was no voltage at the solenoid valve terminals.  It was hard to push my big wires into the terminal board, but I finally secured the connection!
Posted on Jan 28, 2009
Solenoid valve
The humidistat could be defective.
Dec 04, 2013 | Aprilaire 700 Humidifier
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from www.aprilaire.com
Feb 05, 2010 | Aprilaire 700 Humidifier
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
I have a model #560..turning the humidistat forward until it "clicks" would cause the water to begin flowing..now, after the "click" is heard, the water does not flow into the reservoir. Do you think it's...
turn the saddle valve in and back out. sometimes the small pin hole for the water gets plugged with something over the summer when the units aren't running and just turning the valve in and back out clears it out and allows the water to flow. check to see that you have water flow at the solenoid and if you do then it is probably the solenoid that is bad.
Dec 07, 2009 | Aprilaire Humidifiers
Aprilaire 560 will only click and flow water when turned to "test" does not work in any other settings?
Humidity must be hi enough in the house or Humidistat is not working. Do you any way to check humidity in the house?
If the Humidistat is set as Automatic, try to leave it as Manual.
Dec 03, 2009 | Aprilaire 700 Humidifier
Fan running but no water flow
the humidistat on this unit just acts as a set of dry contacts. with the humidifier plugged in, you should be able to touch the 2 brown wires by the water solenoid together and get the power fan to run and the water solenoid to enrgize. if you do this and water does not flow, you most likely have a bad water soenoid. it is either electrically bad, or just plugged with water deposits. sometimes you can pull it apart and clean it, sometimes you just have to replace the solenoid.
Jan 26, 2009 | Aprilaire 700 Humidifier
Looks like my humidistat calls for coil fan and for furnace heat
It sounds like the humidifier may be improperly wired.
It's hard to solve without checking the wiring, but it seems like the humidistat is wired so that as the dial is advanced, it incorrectly turns on the fan, or furnace, or both.  The contacts of the humidistat should be wired so that they turn on the solenoid only.  Also, the power to the humidistat, to turn on the solenoid, should come on only when the fan is on.
Hope this helps!
Jan 03, 2009 | Aprilaire 550 Humidifier
Aprilaire model 760
It could be that the humidistat is not calling for humidity. Make sure that you have the dial turned up all the way (as far as it will go, just to test it) and that the blower on the furnace is running - if the unit is properly wired, the water will not run unless the blower on the furnace is running. This should do the trick. If not, the only other thing would be a bad humidistat. Good Luck!
Dec 14, 2008 | Aprilaire 550 Humidifier
Aprilaire 560 humidifier
Hello All,
Was having a similar problem. Disconnected the source line and opened saddle valve. I was getting water to the solenoid but nothing out the other side. My humidistat doesn't have a "test" setting, it's either off or the highest humidity. I held the outbound line in my hand and experimented with adjusting both sadlle valve and humidistat. I didn't get any water until I opened the saddle valve MUCH further than I thought was necessary and turned the humidistat to near the highest setting. Once I had water coming though I experimented with the setting on the humidistat, turning it off and then slowly increasing the humidity until the solenoid clunked and water started coming out. I would recommend anyone having this same problem to open the saddle valve all the way (I was surprised how many turns that took) and set the humiditstat to it's highest setting.
Randall
Dec 15, 2007 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
375 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
