Question about Maytag Neptune Washer
Maytag neptune washer MAH3000AWW
Washer will not spin water out of clothes at end of wash cycle and the door lock light is on.
  • 1 more comment
  • posey1971 Jan 21, 2009
    washer will not spin the clothes out sometimes it does it good and sometimes it hardly spins them out at all
  • Anonymous Mar 01, 2009
    machine does not drain water out
    need diagran of maytag nepture washer
Order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Posted on Jan 12, 2009
Maytag neptune mah3000aww washer. It cycles then sits at the end of spin, does not go off. then the door will not unlock. I turn to off, push off button. it is anyones guess if it opens
Possible that the door lock is not actuated to open after the end of the cycle and could be jammed. try using a degreasing spray like WD 40 and if there is any issue with the lock.
check this link: door lock
Jul 05, 2012 | Maytag Washing Machines
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washer door lock light and lock does not work on my Neptune Model # MAH3000AWW. also the cloths don't spin dry they are very wet after the spin cycle.
NEPTUNES HAD A PROBLEM WITH THE WAX MOTOR THAT LATCHES THE DOOR, DISCONECT THE POWER, REMOVE THE SCREWS ON THE TOP OF THE COUNSULE. TIP THE COUNSULE TWARD YOU AND DOWN. YOU WILL SEE THE MAIN BOARD LOOK FOR THE R-11 RESISTOR AND SEE IF ITS BURNT.IF IT IS YOU NEED A NEW BOARD AND DOOR LATCH WAX MOTOR. IF NOT YOU HAVE A PROBLEM WITH THE LATCH ***. GOOD LUCK!
Jan 16, 2010 | Maytag Washing Machines
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
377 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
