Wireless mouse stops working
I have changed the mouse batteries to new ones (several times) the cord piece blinks blue then stops and mouse stops.
    President:
  • 8,637 Answers
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver burron and then press the button on the mouse. This should be fdone when ever you change batteries or glitch. Hope this helps you. Bud
Posted on Jan 11, 2009
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My mouse just stopped working. I changed batteries but it won't turn on
Their is a button at the bottom of mouse and base (detector) many times, you have to press it for a second or two, one after the other.. You will see infrared light go on and probably blink, just click the left mouse button and it should work. I have had these mouses before. I much prefer the corded ones.
Oct 14, 2009 | Logitech Cordless Mouse
Mouse does not work. has new batteries, was working, just stopped, changed batteries then nothing. got to help me please.
Change batteries of mouse. if it does not help then uninstall driver for mouse and reinstall it.
and the also if it does not appear to work then its time for getting new one.
good luck
May 13, 2009 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Wireless optical mouse light does not blink
possible solution, is replacing the batteries. if the sync light blinks we round up with a battery problem but if not. its going to need a replacement i hope that helped. hit me back.
Apr 30, 2009 | GE Wireless Optical Mouse
Logitech cordless mouse won't work right. Hard to stop in one
Have you connected the mouse and keyboard to the receiver? There is a button on the bottom of each marked "connect". Press and hold the button down and watch the light on the receiver. The blinking will change when the device is recognized. It should operate smoothly after that.
Let me know how it works out.
Feb 19, 2009 | Logitech Cordless Optical Mouse for...
Wireless keyboard is blinking a blue light but nothing else is working
Normally Dell keyboard require a wireless uSB plug in that connects to your computer and there is usually a small button on both the keyboard and the end of the connector. Press them both. Normally preplacing batteries causes the connection to be disrupted.
Mar 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
My new Nexxtech NWOMMI cordless mouse is not working
Here is what I found about the Nexxtech Notebook Wireless Mouse (NWOMMI):
1. The 2 AAA batteries must be inserted correctly. Look carefully at the "+" and "-" marking on top of the battery compartment and put your batteries in accordingly. Otherwise the mouse will not work, and could be damaged. After the batteries are inserted, the red light at the bottom of the mouse should come on. More on batteries below.
2. Insert the USB receiver into a USB port. The blue light should come on. Press the little button next to the blue light and the light should start to blink,
3. Whild the blue light is blinking, press the connect button at the bottom of the mouse. It is the big black dot inside the white label. Check that the blue light on the receiver is blinking faster, and then change to a steady light.
4. Now check the function of the mouse by moving it on a texture surface.
5. If all goes well, your mouse should be working.
However, here is the bad news. Either due to bad design or some flaw in manufacturing, the mouse consume batteries like crazy. I used fully charge NiMH AAA batteries and they last for only a few hours! And the worst part is that, I checked the batteries when the mouse stop working, ONE of the batteries is COMPLETELY drained, in fact it registered a reverse voltage of -0.1 volts (a charged values is +1.2 volts). This is definitely engineering problem. Note that even when the batteries are in this state, the red light may still come on, and sometimes the re-connection seems to be ok (i.e. the blue light blink faster and then changed to steady). However, the cursor will not work when you move the mouse! Recharging the batteries and the mouse will work again.
Based on the above observation, the mouse instead of having a power-saving feature, it actually has a power-wasting feature!!!
Nov 12, 2007 | NexxTech NWOMMI Mouse
Microsoft wireless multimedia keyboard 1.0A
I suppose you should reset the keyboard and mouse and maybe the access point itself. Try find small buttons on each devise and press them AT THE TIME. You may need somebody's help. Those buttos can by hidden under mouse and keyboard and should be on the top of the access point. This depend on the model, so please reffer to a manual.
Oct 21, 2007 | Computers & Internet
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
