Question about Kodak EasyShare CX7300 Digital Camera
Can't charge camera on printer dock
I am having trouble charging my camera,I contacted Kodak and we done a couple of tests with the docker and everything appeared to be ok there.Kodak have sent me a replacement battery pack and I am still having the same problem,when I place the camera on the docker the print lights come on then,window showing battery low,then eventually camera goes off and the charge lights do not come on at all,hope somone can shed some light on this for me.Thankyou
  • rbutterfly Mar 24, 2008
    my camera turns of even if it has new batteris
  • 76 Answers
Look for decay on contacts on camera and docking station.you could try to get some contact cleaner or switch cleaner from your local electronics shop.just spray small amount into both sides and insert and remove camera from docking station a number of times and see if this helps.
Posted on May 16, 2007
    Genius:
  • 2,985 Answers
Go bak to Kodak- looks lick a Dock/Camera mating problem
When you buy a m753 kodak does it come
Kodak sells three different package versions of their cameras. You can purchase one of their cameras with an adapter but no dock, with adapter and dock, or with adapter and printer dock. The dock and printer dock are also available on line (try eBay) as accessories. The dock is an extremely handy accessory, allowing automatic charging and computer connection. The printer dock though, at least in my experience, is a cumbersome and unreliable method of obtaining low-quality photos.
Nov 07, 2009 | Kodak Easyshare M753 Digital Camera
When i dock my camera it just won't charge. green
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare Z760 Digital Camera
My Kodak G600 printer dock will not recharge my Ni-MH batteries.
you're right. You only can charge the Orginal KAA2HR batterypack of kodak in the cameras.
Aug 26, 2009 | Kodak Easyshare G600 (1633379) Dock /...
My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Jan 25, 2009 | Kodak EasyShare DX4530 Digital Camera
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
I have a kodak c610 camera with the c613 dock but it will no longer charge when i put it on the docking station.
check the contact points of your docking station and your camera. check if there are any obstruction. try dusting it off and recheck
Aug 09, 2008 | Cameras
Kodak CX7430 can only take 10 pictures with a new battery
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Mar 08, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Docking and charging digital camera
Not sure if this will help, but you might try removing the batteries from camera, then see if it responds on the dock, if so it is most likely bad battery. That battery should be easy enough to find at locally. You might wanna try the Interactive Troubleshooter on Kodak's site. http://www.kodak.com/global/en/service/products/ekn030483.jhtml?pq-path=6861
Jul 28, 2007 | Kodak Dock Plus Bluetooth Thermal Printer
Kodak EasyShare CX7300 Digital Camera Logo
104 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
