Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
My Jenn-Air stainless steel dishwasher shows an error of L3.
It was running fine then last night when I went to set the controls, which is inside the door, the L & symbol had a 3 flashing inside of it & I cannot get the dishwasher to work.
Sea Breeze
  • 4655 Answers
SOURCE: jenn air 24 in jdb2100aws
Link below has everything you need to get answers. Hope this helps.
http://personafile.com/Jenn-Air-Dishwasher-JDB2100AWS-P0719881000055.htm
Posted on Feb 02, 2009
SOURCE: Jenn-Air Dishwasher Handle Loose
This worked perfectly for me. Follow the link that shows you which two screws to take out. It is one screw on each side of the inside door frame. One on the left and one on the right (not the top one, but the second one down). Then pull the door handle upward about 2 inches and the whole washer face comes up. Jiggle it off and tighten the handle. Only tricky thing is that you need a star screwdriver.
The problem I had in the beginning was that I took off the middle screws on top (cause that's what it looks like in the picture), but it's actually the side screws. Don't take them all off - just the two you need.
- Pokey
Posted on Nov 03, 2009
SOURCE: Our jenn-Air built in dishwasher smells foul and
We had similar type of problem (as well as residual water always left in bottom) and after pulling out the dishwasher, found that the drainage tube was incorrectly installed by contractor. It was laying on the floor behind it with a only a slight rise to the garbage disposal inlet. I suspect this contributed to sewer odors as well a water back flowing into the dishwasher. I disconnected drainage tube so that it went up 24+" and then connected to garbage disposal (creates a loop that blocks sewer odors and back flow conditions). I also cleared out the filter at bottom of inside the dishwasher. The Use & Care Guide suggested using baking soda in China/Crystal mode for 10 minutes, opening the front door and letting it sit overnight. I repeated that for 3 nights and it did clear up the remaining odor. Don't know if this will help your issue or not. Good luck!
Posted on Jan 10, 2010
  • 677 Answers
SOURCE: The inside of the dishwasher bottom is a film like
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
Posted on May 26, 2010
rickead1
  • 1998 Answers
SOURCE: 2 year old stainless steel dishwasher making weird sounds
are u hearing any metal grinding sounds or is it making a noise like something is breaking theres a pump located down the bottom of the unit and depending on how you wash your dishes for example if you wash them before you insert them into the dishwasher or if you put them in with food on them would consitute your next course of action if you do insert them with food on them then you would need to check the pump and the chopper area you might want to call a technician if the problem persists. hope this helps try running it through the full cycle if tere is something wrong you will get an error code
Posted on Jul 13, 2010
The door is getting rusty. I believed that stainless steal didn't rust. Is there a way I can remove the spots?
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to this site.
Mar 22, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
My dishwasher will not start. I can chose my settings close the door and press start but it will not start.
You have a bad control panel. Here is your part#99003139
  1. Unplug your dishwasher
  2. Unscrew the the screws that run along side the inner door *don't let door drop*
  3. Unplug the ribbon cable and replace the control panel
This would only take 20min to change. Have a great day!
Dec 08, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
DOES JENN AIR HAVE A REST BUTTON, MY DISHWASHER WONT START. MODEL NUMBER JDB4000AWS
first of all if its a built in dishwasher under counter by the sink,check for a switch as you may have inadvertentally switched this switch off or unknowingly bumped it with something under the sink,then if it has power to the unit,there is a built in fuse on the control board
Nov 26, 2010 | Jenn-Air JDB4000AWS Stainless Steel...
The inside of the dishwasher bottom is a film like covering. it is cleaning dishes great, but the stainless steele bottom looks awful. HELP!
this is usually scale build up and can be remove by using lime away. and run the unit in an empty cycle. there are dishwasher cleaner that can be bought from local parts or home improvement store
Mar 28, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Our jenn-Air built in dishwasher smells foul and has since the first time we used it 4 months ago. we have tried bleach, vinegar, finish brand dishwaher cleaner, less soap, cascade soap, running every day,...
Jan 09, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Jun 22, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jennair dishwasher jdb1250aws not drying fully and compartment is still damp inside
There should be an led control panel, select menu and you should see an option there to enable your wi fi
Feb 28, 2009 | Jenn-Air 24 in. JDB1250AWS Stainless Steel...
Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
Sep 03, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
138 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
