Question about Xerox WorkCentre Pro 416 All-In-One Laser Printer
Can't get the old drum to come out of the copier. It seems as if it is caught up on something. I have a workcentre pro 416
  • tek_dejr Dec 31, 2008
    Thank you for you help it worked perfectly.
  • Anonymous Jan 23, 2009
    i CAN'T GET THE DRUM OUT IT FELS LIKE IT IS HUNG ON SOMETHING
    President:
  • 2,072 Answers
When you open the right side door, look toward the back, about 4 inches above the drum. You will see a pin about 1.8th of an inch in diameter. It is spring loaded but is most likely stuck in. Just pull it out gently and it should slide out, releasing the drum shutter, that should allow you to remove the drum wheh you depress the handle.
That is the most common reason that drum will stick.
Posted on Dec 30, 2008
  • Rick Kasper Dec 30, 2008
    I meant 1/8th of an inch, not 1.8 inches.
  • Rick Kasper Jan 02, 2009
    Your welcome
TRYING TO PULL OUT DRUM FOR A
please open the right side door then open the front door and try to slide out the drum.
Aug 08, 2014 | Xerox WorkCentre Pro 416 All-In-One Laser...
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
Oct 13, 2010 | Computers & Internet
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Fax issues - Workcentre Pro 416 S
Sounds like a phone line issue. Noise, static, low line voltage would cause that. It;s not a digital phone line or VOIP line is it? A 416 requires an analogue line.
Jan 27, 2009 | Xerox WorkCentre M-24 Color Copier
Installation of workcentre pro 416 drum
Just sendig this to get your message off the baord. I sent you the most likely problem.
I will add you may want to see if the pin assembly is broken. You can clean that shafe and lubricate it.
Dec 30, 2008 | Xerox WorkCentre Pro 416DC Copier
Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    Xerox WorkCentre Pro 416 All-In-One Laser Printer Logo
    172 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
