Question about Hardware & Accessories
MintCraft entry door lockset one will not stay locked ,
Installed new handle in old entry door one releases with outside lever another will not unlock
  • 35 Answers
Try reversing or flipping them upside down.....If you put them on in the same day, Parts may have gotten Mixed up..... Try combining and Such as to make Things work....As long as you have all the parts that came with it...It should work.......Hope this helps.....Joe
Posted on Jan 11, 2009
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
How do i attach the door lever?
Kwikset lever handles are held on with hex set screws. A wrench is included in the package. It's either a 3/32" or 2.5 mm. Note that the lock must be unlocked to remove or install the outside handle.
Sep 06, 2014 | Kwikset Brooklane Venetian Bronze Entry...
You can get them through any dealer, but they will have to be ordered that way, they don't come mastered .
Mar 31, 2014 | Mintcraft 6068274 Entry Lock Knob Ab 6-Way
1998 sienna driver side sliding door lock sticking
You can take off the interior panel and fix it there:
Mar 28, 2017 | 1998 Toyota Sienna
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
2002 Hyundai Elantra Drivers dorr Lock Jammed not unlocking properly. Lock lever on inside and key on outside are stuck and door move bery much and will not unlock car. Originally cable in door to release...
Same thing happened with mine. It turned out that the power door lock motor went out. Since the handle or the switch can unlock the driver's door, both of these mechanisms are connected. When the door lock motor goes out it freezes in whatever position, it was last engaged.
Nov 06, 2010 | Hyundai Motor 2002 Elantra
My daughter called saying that the driver's side door on her 1998 Honda accord won't open. Door locks/unlocks both manually and with interior switch...window operates fine...exterior/interior handles seem...
You didn't mention if the inside release works. Typically there are little rods and levers involved and something comes loose. If you find a rod off, do something, as it will want to pop off again, only sooner. Sometimes you find broken plactic and you need to get a new part.
It is annoying to get into the door if neither inside or outside will release the door.
Some doors are affected by pulling on a lever, near the time unlock button was pushed... If lock, and unlock )with no levers being pulled (by you)) does not release it, surgery is next step.
Oct 08, 2010 | Honda Accord Cars & Trucks
94 chevy lumina apv door will not open most of the time
since it is the drivers front door it could be the outside door handle , the rod that goes from the handle to the lock asbly or the lock asbly its self take the door trim panel off and then loos inside the door and latch the door with the door open. open the door with the outside door handle and watch the rod and the lever that the rod is pushing down the lever might not be pushing the lever down far enough to release the lock. If the lock does not open try pushing down on the lever and see if the lock releases if it does ck the outside door handle for cracks along the hinges of the handle I have found that most of the time that it is the outside door handle cracked and the rod is not moving the lever far enough to release the lock.
Feb 20, 2010 | 1994 Chevrolet Lumina APV
Hardware & Accessories Logo
182 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
