Question about Pfizer Electronic Rubiks Cube Rubik's Revolution
I had to install new batteries in the Rubik's Revolution, and now
There is no sound. Is there a reset button somewhere?
  • 3 more comments
  • Anonymous Dec 31, 2008
    same problem installed new batteries now the sound doesnt work any answers reasonable ones???
  • Anonymous Mar 21, 2009
    I have the similar issue
  • Anonymous May 01, 2009
    ya now im wondering did they rip me off i wont buy their products tell the problem is fixed
  • Anonymous May 25, 2009
    yea me too except i didnt  install new battiers the audio just doesnt work
  • Edward May 14, 2012
    where do you put the batties at?
Take it back to shop .probably a loose connection.
Posted on Dec 30, 2008
Inventor rubiks first name?
a very easy Google, 'Erno'.
Ern? Rubik - Wikipedia
https://en.wikipedia.org/wiki/Ern?_Rubik
  1. Cached
  2. Similar
Ern? Rubik (Hungarian: [?rubik ??rn??]; born 13 July 1944) is a Hungarian inventor, architect and professor of architecture. He is best known for the invention of mechanical puzzles including Rubik's Cube (1974), Rubik's Magic, Rubik's Magic: Master Edition, and Rubik's Snake.
Inventor rubiks first name Google Search
Dec 23, 2016 | Toys
Hard Boot LG Revalution
Please note that all data will be deleted from the LG Revolution as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your LG Revolution is frozen, pull the battery out and reinsert it
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Revolution. Once the wipe is complete, the phone will reboot to its factory fresh state.
Your Welcome :D
Aug 29, 2013 | LG Cell Phones
Ordered new set of blades for 42" revolution. The
From what your explaining it sounds to me that you may have received the wrong parts for your machine. Possibly a packaging error. Take them back to your supplier , explain the problem, and they will check on the accuracy of the order, or tell you what you may have done incorrectly. GOOD LUCK.
Jul 07, 2011 | Craftsman Revolution 42" Briggs Stratton...
Dog ate instructions to rubix revolution . how do i get them?
The official instructions for Rubik's Revolution can be downloaded as a PDF file from their website: http://www.rubiksrevolution.com/manuals/english2.pdf
Sep 07, 2010 | Pfizer Electronic Rubiks Cube Rubik's...
Broken shock, can't remove
You can call OCTykes.com @ 949-429-1714 if you still need it fixed.
May 26, 2010 | BOB Trailer Revolution Stroller
My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
Apr 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Honda Odyssey 2004 no alarms
There is most likely a reset button under the dash somewhere. You can try pressing and holding that button down while pressing the lock button on the remote. If this does not work simply have the dealer reset it for you.
Jan 06, 2010 | 2004 Honda Odyssey
BC300 model odometer registers twice the mileage ridden after putting a new battery
I don't have this model but understand many odometers, like mine, reset the wheel size to wrong setting when battery replaced. Go to setup screen to reset to correct value. Setup screens normally appear if buttons held for about 2 seconds or more. Some models require millimeters and some centimeters. If you don't have a figure for your tyre measure the distance on the ground for one complete revolution of the wheel.
Aug 17, 2009 | Sigma Cycling
Power button
Hi There should be a reset pin hole on the camera somewhere. Check the manual for the location. Then press the on button and use a paper clip to insert into the pin hole right after. This should rset the internal computer. Hope this helps.
G.Evans
Ontario, Canada
Jun 22, 2009 | Fuji FinePix F480 Digital Camera
Lift off won't **** up.
Check both filters and give unit time to sit. Thermo switch can take several days to reset.
Nov 03, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Pfizer Electronic Rubiks Cube Rubik's Revolution Logo
1,031 people viewed this question
Top Pfizer Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Pfizer Toy Expert? Answer questions, earn points and help others
