Samsung plasma has no picture but sound
Hps4253x/xx model ,no picture no menu and cant see volume go up or down but sound goes up or down.I checked all inputs . What board needs to be replaced i have it open looks like 4 or 5 main c. boards all fuses are good.TV is 23 months old .Jan of 07 .the repair cost is same as buying it new , I spoke to a repairman. I want to fix it myself . if not it goes to the curb. thanks Art
Hjhjkhkl
Posted on Dec 31, 2008
  • thewaz Dec 31, 2008
    Get your kids away from the tv it only has a life span of 60000hrs.Or your wife sit in front of it all day on her fat --- while your at work.ART please post if you bring it to the curb i will glad to take it off your curb.You should bought a VIZZO,
My TV (Toshiba or Samsung or something like that) a flat screen will uncontrollably go down in volume and if I take the batteries out of the remote it still adjusts it's own volume down. I've tried th
Well the difference between a Samsung and Toshiba are pretty extensive, so without knowing what TV and what model, we cant help very thoroughly. Have you checked with the manufacturer directly? it sounds like the TV is quite new.
Oct 08, 2014 | Toshiba Televison & Video
Samsung plasma tv #pl42b430p2d volume turn up &down itself
hi the v+ is dirty or just bad maybe every taster
Nov 26, 2013 | Televison & Video
I have a 2010 50" Samsung plasma hd 3d tv. I woke up one morning and had no picture. I had sound and could change the channels and listen to whatever was on, just no picture. no picture in menu, or source...
It is not an easy task to repair a Plasma TV, for any inexperienced user. It will be best to contact any service technician. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 20, 2013 | Samsung 50" Plasma Pn50c7000yf Main Logic...
Samsung plasma 42" model HPR4252xlxaa only have picture in center of screne the rest is black or black mesh. sometimes the whole screne brightens up for 15 to 30 seconds with great picture then goes b
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 02, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
I have a samsung plasma 42" model hps4253x/xaa -the plasma has a green vertical line at the left side.
Did it come this way? If so I would recommend returning the TV. I'm guessing you have tried using different channels, inputs, etc. If not please do so to determine if it might be specific to an input or channel. This is not something that someone will be able to talk you through via message boards. I would first try calling the manufacturer and then the retailer if you continue to have problems.
May 05, 2011 | Samsung SP-R4232 42 in. Plasma HDTV
Sound no picture
Sound but no picture....
Should ask yourself, does it PRIME? Meaning, That's where the Plasma panel lights up a little for about 10 seconds after startup. -- If it doesn't prime, then you need either the SMPS, YZUS, possibly both. OR you might need to check the ZSUZ. Driver boards can be culprits too.
And can you even get to the Menu, Volume, etc. but just picture?
Then you need the signal board.
Unfortunately that's pretty common with Plasmas. Can burn out or burn "in" easily.
Here's a great forum you might like. http://www.austech.info/electronics/20607-lg-plasma-tv-has-no-picture.html
Different Brand but similar problem. This site is excellent for do it yourselfers. As for Samsung Parts, be thankful if you are a DIY-er that the parts are much cheaper if you install yourself. Separate with installation adds up very quickly. Personally, I decided to go with the Rear Projection Samsung several years ago and haven't had any major problems. Heard then that Samsung was having lots of complications of this nature.
Here's the link to Samsung Site:
http://www.samsung.com/us/support/owners/product/SPN4235
You can try the tricks on this site:
http://www.broadbandreports.com/forum/r22996341-samsung-spn4235-sound-but-no-picture
To be honest though sounds like either bad SMPS and/or bad Y-SUS pcb's.
Wish you good luck.
Mar 08, 2011 | Samsung SPN4235 42 in. Plasma HDTV
Model hps4253x/xaa vertical lines throughout screen
Need more specfic info. Are the lines on all sources? Are the lines as thin as a Pinstripe?. The possible causes are: The Main bd is bad or the P-Logic bd is bad or the Plasma Panel is bad. Have a trained samsung tech troubleshoot the set.
Jul 13, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
My new samsung ps42a457 plasma tv wont keep its modified settings
hi hold down exit botton until menu appears,it is set in shop demo please select home use and follow instructions that will sort it
Mar 26, 2009 | Samsung PN42A450 Plasma TV
Televison & Video Logo
523 people viewed this question
Top Televison & Video Experts
