Question about Pioneer DV-340 DVD Player
Power supply burned out (Model: ZN1792-F2)
The power supply has a lot of burned resisters that is not possible identify the values.
The ones are not possible to identify are: R23, R24, R9, R7. Can anybody help me on this?
2 Suggested Answers
premtech
  • 934 Answers
SOURCE: Pioneer PDP42mve1 No Power
The resistor is a low ohm, probably in the smps, and the fact that it heated up was probably due to a short in the regulator. This is one you'll need to have serviced because of all the equipment you'll need to trace and diagnose the problem..
Posted on Nov 05, 2007
What is the actual value of burned resistor (R607) from power supply of TV KV 32S10
You're asking about the resistance value of the resistor, I assumes. Try to download the repair manual to this set by internet. It has all details. If you wish to get some details about the power supply section schematics to some models, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Aug 03, 2013 | Sony Televison & Video
Apex LD4088 no picture
The inverter is the usual suspect with that symptom. It may be hard to find a replacement inverter for an apex model. But you might be able to get one from www.tvrepairworld.com
Oct 29, 2012 | Apex Digital LD4088 LCD TV
What is the value of the resistor that burns up when to much RF power is input?
Hi wrightjc2,
Most common burned resistor are those with low resistance because it acts like a fuse to avoid further damaged to some parts if shorts,overload happened. But still best to have a schematic diagram to identify the burned one. If you haven't a schematic you may get the resistance of the resistor, measure it to the middle where the burned cut out, add the resistance from one half side to other half side. You may now have an Idea what may be the value of the burned resistor.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 25, 2011 | Pyramid (Swr14) Swr&Power Field Strength...
Error Code 2-2. (Low Voltage Supply) What now?
That is a power supply issue and this requires a skilled person to do it.Trouble shooting in this kind of problem includes voltage measurement and resistance reading of the components/parts inside the high voltage section This is not a DIY problem but if you still want to do it yourself then I can give you some guide that you can try.
1.Check the power supply board,this board is where the power cord is connected.The common problem on this circuit are the filter capacitors .A leak and shorted capacitors always cause that kind of problem the worse is dead set.To visually identify a defective capacitor is their appearance they look to be bulging on top blown,theirs a liquid leak on the body.replace the defective capacitor if you found any.with the same rating and value..
2.Resistors -change value resistors and open resistance can cause the same problem this resistors usually near the regulator transistor.They appears as burned and overheated replace it with the same rating there is an available color code calculator of resistor in the internet click this link and key in the color of the resistor to get the value..
3. check the voltage regulator transistor if it is shorted .the first pin and second pin must not have a reverse reading..
4.Check also the two big IC marked with STK xxxx this IC are the convergence IC it controls the horizontal pin of picture..when this IC are defective this will shut down the power supply ..
The steps I mentioned must be done with a skilled personnel If you feel you can do it,well you can try or better yet bring it to the service center or call a service technician...click this link for service center
good luck hope this helps!
Feb 06, 2011 | Mitsubishi VS-60705 60" Rear Projection...
Loud bang then dark screen, no picture, no sound.
hello,
Assuming there are no other symptoms:
If this appears after extended operation - an hour or more - it may just be a build up of dust, dirt, and grime over the years. After understanding the safety info, some careful vacuuming inside may help. Just don't be tempted to turn any screws or adjustments!
Dust is attracted to the high voltage section in particular - even the front faceplate of the CRT collects a lot and should be wiped with a damp cloth from time to time.
If the symptoms develop quickly - in a few minutes or less, then there could still be a dust problem - a power resistor may be heating a wad of it but other possibilities need to be considered.
If not dust, then probably in the power supply but realize that TVs don't have a nice metal case labeled 'power supply'. It is just a bunch of stuff scattered around the main board. Without identifying the part that is heating, a diagnosis is tough especially if the set really does work fine otherwise. However, if a series regulator were faulty and putting out too much voltage, the set could appear to work properly but in fact have excessive power dissipation in certain components. If cleaning the dust does not solve the problem, you will probably need a schematic to identify the correct voltages.
Also, A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 01, 2010 | Televison & Video
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Mar 09, 2009 | Computers & Internet
450W ATX SMPS of Intex
sir all smps can be reapired using indian jugar technique. first of all see twi diods under the burnt transistors check them they are short then check the capacitors if they are not leaky or pregnant then see bridge reactifier change all that looks short or open then replace all and the transistors with 13007 transistors(jugad) be careful that 13007 must be isolated from heat sink that means metal part must be fixed to them but not short to them . replace the fuse with 2 ampere fuse (for safety) ..... have fun
Jan 21, 2009 | ASUS PSU | A-45GA 450W RT (A45GA) Power...
Sony kv 29x5d
Please mention correct model number to check C633 value.
My system recognise this model as incorrect.
Jun 01, 2008 | Televison & Video
Pioneer DV-340 DVD Player Logo
292 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
