Question about Kitchen Ranges
Top oven off by 85 degrees
Model PLEB30T8CCB bottom oven working great . Bottom heats up but off by 85 degrees
  • jlivaudais Dec 30, 2008
    The top is not heating . The bottom is working fine. I changed the element but still not working . The display will say 425 but it will only be 340 inside.
    Genius:
  • 1,913 Answers
U have to resetr your own heating limit.
increase your oen limit. to higher then 85
Posted on Dec 30, 2008
    Genius:
  • 2,035 Answers
Check the door switch in the top oven it could be defective and if the temp display wrong then it could the temp sensor problem ...
Good luck...
    Genius:
  • 1,550 Answers
  • Overheating due to blocked air vents or inoperative cooling fan.
  • Overheating due to bad magnetron.
  • Bad connections in controller or microwave generator.
  • Faulty interlock switch or marginal door alignment.
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Frigidaire pleb30t8ccb top oven won't heat on bake or broil. It doesn't give any error codes. I ohm tested the heat sensor and it showed no resistance. will this keep the oven from hea
Try resetting your breaker first. Next make sure all of your wiring is properly in tact. When you have nothing working, it is usually the power source .
Jan 18, 2015 | Frigidaire Ovens
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
