Question about HP DesignJet 9000 InkJet Printer
Error code 1290
How can I reset my service counter as the machine is powering up so the error code does not pop up
  • benjieone Apr 21, 2009
    i have an HP 9000 DESIGNJET an error 1290 keeps coming up when iniatialization please help - Benjie - Zambia
  • Gary
    Gary May 11, 2010
    I have access to the service manual on this model, but there isn't a listing for Error 1290....stops at 1260, then goes to error 1700.
    Are you positive that is the correct error?
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
2 Suggested Answers
SOURCE: I have a HP designjet
scaner prints weird character - on preview everything looks good, but results are not acceptable
Posted on Dec 30, 2008
Bizhub error code
Have the fusing unit replaced. One attempt only to reset if you continue to get the code the machine can catch on fire! That would ruin a perfectly good day. If the code comes back after this procedure have a qualified Konicaminolta Service tech look at it.. First power off the machine with both switches. Wait 10 second turn on the switch inside the machine then holding down the Utility/Counter button turn on the second power switch on the control panel keep the utility /Counter button down until you get Trouble reset then touch get a OK then power off the machine wait ten seconds power back on.
Jun 26, 2013 | Minolta Office Equipment & Supplies
How to reset bizhub 350
Fuser Warm Up Failure.
This means you either have a fuser unit failure or possibly had a voltage surge. Also sometimes if the machine is turned on in a cold environment this code can pop up. Try resetting ONCE only by turning the machine off, then holding down the utility/counter button while turning the power back on. Continue to hold the button down until you see "Trouble Reset" then touch OK. Turn power off then on again. If the code comes back on after a bit then you will need the machine serviced.
Good Luck.
Dec 25, 2011 | Minolta bizhub 350 Black and White Copier
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Green and red light on doesn't print
Maintenance request error is not cleared until the waste ink pad is replaced with a new one, and the waste ink counter in EEPROM is reset by the service operation.
"try in this procedure
1. hold and press ink and roll button then press power on.
2. Red Led 10 times blinking
3. release roll button.
4. press ink button until all light blink at a time
Dec 31, 2009 | Epson Stylus Photo 1290 InkJet Printer
Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Jul 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I have a HP designjet 9000 and I have the error code 1290 How do I reset my service counter as the machine is powering up
You can reset the maintenance count by holding the green go button on start up as soon as you see the memory count start. Keep holding until all three lights are solid lit then release. Scroll to new maintenance kit and select it.
Dec 30, 2008 | HP DesignJet 9000 InkJet Printer
Epson 1290
this is the service error download the ssc utility from the site, then reset the counter of your printer, your problem will be solved
Nov 10, 2008 | Epson Stylus Photo 1290 InkJet Printer
This is a maintenance request. Basically the internal counter has hit it's limit and now requires that the counter is reset and the ink pads are replaced or cleaned.
Ask at http://www.TheServiceManualShop.com if they do a Rescue Kit for your machine. This should include all the goodies you need to get running again. If they have no kit for machine, let me know as I may have an alternative.
Oct 13, 2007 | Epson Stylus Photo 1290 InkJet Printer
Printer lights stay on
Hi geoger, Can you give more detail about the lights and if they flash and in what sequence. The most likely cause is that your machine has hit the maintenance error meaning that the waste ink pads are full. This requires that the pads be cleaned/replaced and the counter within the firmware be reset. To do this, you will need the service manual for the 1290 to dismantle it and gain accesss to the pads and the software to reset the firmware counter. You should be able to get these from: http://www.TheServiceManualShop.com and/or http://mikeburton.tradebit.com/
Mar 03, 2007 | Epson Stylus Color 660 InkJet Printer
HP DesignJet 9000 InkJet Printer Logo
1,023 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
