Question about Xerox WorkCentre Pro 416DC Copier
Installation of workcentre pro 416 drum
Can't get the old drum to come out. It seems as if it is caught up on something.
  • 239 Answers
The side door pin must be broken. This is not a very good design they break often if the door is not shut right using both hands at the same time.
Even if the latch pin assay is replaced, they break easy.
Lubrication or grease on the shaft pin is of little help.
If it is broken, the black drum cover can be taken off. It just swivels up and down. It should pop off kinda easy. On a new drum this cover can be taken off too.
Just remove that black cover if you can.
Just be careful not to scratch the drum when removing paper.
Reinstall the drum and run copies.
Posted on Sep 15, 2011
    President:
  • 2,072 Answers
Just sendig this to get your message off the baord. I sent you the most likely problem.
I will add you may want to see if the pin assembly is broken. You can clean that shafe and lubricate it.
Posted on Dec 30, 2008
2 Suggested Answers
  • 2072 Answers
SOURCE: can't get the old drum
When you open the right side door, look toward the back, about 4 inches above the drum. You will see a pin about 1.8th of an inch in diameter. It is spring loaded but is most likely stuck in. Just pull it out gently and it should slide out, releasing the drum shutter, that should allow you to remove the drum wheh you depress the handle.
That is the most common reason that drum will stick.
TRYING TO PULL OUT DRUM FOR A
please open the right side door then open the front door and try to slide out the drum.
Aug 08, 2014 | Xerox WorkCentre Pro 416 All-In-One Laser...
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
Oct 13, 2010 | Computers & Internet
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Unimessage pro driver error
try reseting the nvram. if no luck after that try changing the image control board.. with another one if it's avaliable.(maybe you have another machine around. If not then conect your printer to the network reset the printer so you can get an ip address.. usually it's a 192.168.*.* Then type that ip address 192.168.*.* into the top of your web address bar and you should be able to see you printer. If not i would change the image control board because it might be bad.
Feb 10, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Fax issues - Workcentre Pro 416 S
Sounds like a phone line issue. Noise, static, low line voltage would cause that. It;s not a digital phone line or VOIP line is it? A 416 requires an analogue line.
Jan 27, 2009 | Xerox WorkCentre M-24 Color Copier
Can't get the old drum to come out of the copier. It seems as if it is caught up on something. I have a workcentre pro 416
Dec 30, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox WorkCentre Pro 416DC Copier Logo
271 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
