Question about Nokia 6600 fold Cellular Phone
Nokia 6600 Fold - Red light on the top of the phone never goe out
Recently the light on the top of my 6600 Fold is permanently on. The light is red and doesn't go out unless the fone is turned off. Does anyone know why this has happened or hpw to get it to turn off???
  • Anonymous Jan 08, 2009
    Hi Leo,
    Hope you are doing well.
    Please be advised that once the "Light effects" are turned on, it will indicate the standby mode, missed events, alarms and reminders, calls, and low battery level. The only option available is to turn Light effects on or off.
    These settings are predefined, and the phone does not have an option not to flash when in standby mode.
    I hope this information help clarify your enquiry.
    Thank you for emailing Nokia Careline,! Please help us serve you better by providing your valuable feedback at
    http://digiumenterprise.com/answer/?inv=...
    Do you know you can now update your phone software at your own convenience?
    Visit www.nokia.com.au/support to check if your phone model is supported and download the "Nokia Software Updater".
    Kind regards,
    Jeyasegaran
    Nokia Careline
    Please contact us at 1300 881 600
    www.nokia.com.my/support
  • Jenny D Apr 12, 2009
    The screen of my 6600 has died and the light at the top of my handset is now on permanently.
    Is there anything I can do to fix it?
    Jenny
SOURCE: how do i turn my nokia 6600 fold on and off??!
When you flip the phone open on the right side there is a red phone symbol, hold it to turn the phone on or off ..
Posted on Mar 30, 2009
njvinod
  • 1462 Answers
SOURCE: i need a restriction code of nokia 6600 fold
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 07, 2009
skdeepak88
  • 232 Answers
SOURCE: how do you remove battery from Nokia 6600 fold
At the back panel of the phone you ll find cover and a sign to press and remove.
Posted on Oct 02, 2009
SOURCE: Nokia 6600 fold , there is a red light on outer casing
it means your battery is low
Posted on Oct 31, 2009
  • 311 Answers
SOURCE: how do i remove the keypad from a nokia 6600 fold?
  • Remove your back cover, battery, sim and memory card. Remove the six screws you can see.
  • Run something like a credit card under the keypad to release it.
  • With the keypad removed your phone should look like below. Remove the two screws you can see. Then pull the housing in the direction shown by the arrows to release the two clips that hold the circuit board in place.
  • The battery compartment should no be loose. Lift it away from the rest of the phone, as shown.
  • Your phone should now look like below. The circled connector needs to be disconnected. It attaches like a plug and socket. Just lever it up to unplug.
  • You can now lift the circuit board away from the rest of the phone.
  • Run your plastic tool all the way around the join of the front cover to release it.
  • Remove the part shown below. You can either pull it away with your fingernails or lever it off with something like a small flat head screwdriver.
  • You can now remove the front cover, as shown below.
  • The metal frame should also be loose and can be removed. Another ribbon connector needs to be unplugged like the one in the earlier stages of the guide.
  • You now need to slide your plastic tool under the screen. It'll be stuck down with double sided tape so a little force is required.
  • You should now have the LCD screen removed. Reverse the whole procedure for reassembly.
Posted on Feb 11, 2010
Testimonial: "Brilliant thanks for the guide!"
How to unlock a nokia 6600
To Reset the Nokia 6600 from security lock use the master reset code....Visit the site Onlinegsmunlock.com/nokia-dct-master-code-service/rs7wp10/ get Nokia 6600 master reset code and reset from security lock.
Jun 26, 2012 | Nokia 6600 fold Cellular Phone
Hp nokia 6600 terkunci dengan kode kunci telepon,bagaimana cara membuka kodenya
saya dikasih hp nokia 6600 tapi yg pny hp lp akn sandy pd lyar tlp untuk merestr bgmn caranya
Apr 29, 2012 | Nokia 6600 fold Cellular Phone
Lost my manual, from where can I download a copy.
Here you go
http://nds1.nokia.com/phones/files/guides/Nokia_6600_fold_UG_en.pdf
Kind Regards
Jim
Jan 17, 2010 | Nokia 6600 fold Cellular Phone
How do you remove battery from Nokia 6600 fold phone please?
Oct 02, 2009 | Nokia 6600 fold Cellular Phone
Dropped Nokia 6600 in cup of cold coffee - now no power. Where is on/off switch, please?
The On/Off switch is the top of the phone. It is a long rubber button and has a red symbol on it.
Jul 10, 2009 | Nokia 6600
How do i turn my nokia 6600 fold on and off??! I cannot find the on/off button.
Mar 28, 2009 | Nokia 6600 fold Cellular Phone
White flashing screen & red light permanent
this complaint is probably software complaint so flash your phone
Jun 29, 2007 | Sony Ericsson K750
Nokia 6600 fold Cellular Phone Logo
719 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
