Question about Simplicity Serge Pro SW432 Mechanical Sewing Machine
Serger won't run
My serger machine won't run ,i was working with it and all the sudden it stopped like it had stucked on some thing. the motor just makes a little bit of noise when i step on the paddle and then it won't run
  • Anonymous Dec 11, 2007
    simplicity serger SL800. I cant get the thread to make a chain. It looks like it is threaded properly and needle inserted with scarf to the back. It was working fine till i had to change the needle.
Check the needles and make sure the looper isn't stuck between the needles causing them to bind. Open the front cover and look at all the usual moving parts, Try to operate the unit by hand and carefully look at them to see if something is binding. If you have a digital camera take a picture of this area and post it if possible.
Posted on Jun 14, 2007
Serger problems
I love/hate my serger! Is thread stuck anywhere below? Bent needles? Are the needles in correctly and tightly? Is the machine greased? Unthread it, rethread. After all of this, it should work. Good luck. My simple old singer didn't do this but it wore out and the Viking is temperamental!
Jun 04, 2013 | Sewing Machines
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
FS320 serger needles won't go up and down. New
if the machine is still under warrenty, take it back
if it's not under warrenty, take it to the place you bought it from & tell them
May 28, 2012 | Yamata Sewing Machines
Serger won't sew
is there any smell to the machine?
it's possible that sewing the thick fabric could have caused the machine
to jump time
it would be a good idea to have it serviced at a sewing machine shop
Apr 28, 2012 | Elna Sewing Machines
I have a brand new Singer Pro Finish Serger and it won't sew. When I press on the pedal it makes noise, but the needled do not move. Nothing else happens.
are the cords for the power & foot pedal plugged in correctly?
the only thing I can suggest is taking the machine to a sewing machine shop
to be checked
or check on youtube or ehow that can help you
Apr 12, 2012 | Sewing Machines
What is wrong with new home overlock serger when motor is slugish or won't move.
there is something wrong with the machine, the feed dogs are what move the fabric, it could be many different thing, the motor, some part is worn or loose or broken, power cord, it needs to be serviced
Feb 27, 2012 | Sewing Machines
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
My serger won't start. Motor is running but won't turn. Also wheel wont turn
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
Jun 05, 2011 | Husqvarna Huskylock Computerized 905
Singer Tiny Serger: Motor runs but machine
pull the 4 bottom rubber feet out and remove screws hidden in holes. Lift main body of serger up. you will see the gears. Probably drive gear on motor shaft got hot and slid on motor shaft.
Dec 10, 2009 | Singer Tiny Serger TS380
Simplicity Serge Pro SW432 Mechanical Sewing Machine Logo
296 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
