Question about Canon imagePROGRAF W6400 InkJet Printer
Canon Image Prograf w6400 error E02802
I keep getting an error that says E02802, check printhead. I've done printhead height adjustments, but to no avail. I just replaced the printhead, and it still gives me the message. What is going on? Please help!
  • Anonymous Feb 23, 2009
    Erroe e02802
  • ghorne Apr 24, 2009
    I've tried what your tech guy suggested (turn off printer). Same error, I also checked the print head made it was seated in position. no luck
    thanks
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
Hardware error 03130031-2618
Mario, Re POST , make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 04, 2016 | Canon Office Equipment & Supplies
Cleaning kit print head canon Image prograf 710
I have always cleaned prinheads leaving them on a saucer with warm water for some time. Preferably, deionized water if it is a problematic printhead. I expect the cleaning kit is something of the sort. But Canon ipf 710 seems to have a fixed use time, having the printer rejecting the printhead after exacly one year use even if it is in perfect conditions. Try to make print test in service mode before you use up all your ink in useless cleanings.
Jul 01, 2014 | Canon imagePROGRAF IPF710 Printer
Error code e02826 after installing new printhead
Reset the print head. While out clean terminals with damp cotton wool. Should start after that if not probably faulty printhead,
Sep 28, 2012 | Canon imagePROGRAF W6400 InkJet Printer
W6400 printhead error
I can not seem to solve the problem where to put oil ooh where we find the sensor ???
Mar 09, 2012 | Canon imagePROGRAF W8400 InkJet Printer
I have a Canon W8200 and i get the error code"
Try this:
1) As an error (E02802 or E02805 to E02809) is shown on the display, install the correct
combination of printhead and ink tanks according to the error.
2) Perform ink filling*3 following the installation sequence. After filling ink, when "Load Roll
Media" is shown on the display, turn off the power.
3) Turn on the printer while holding down the ONLINE button, ENTER button, CANCEL button,
and PAPER SOURCE button.
4) Check that "Canon W8200" is shown on the display, and then release the buttons. When
printer enters Reset mode for the dye/pigment model setting, all the LEDs on the operation
panel turn on.
5) "TYPE RESET" is shown on the display.
6) Select "YES", and then reset the dye/pigment model setting in the printer.
When reset is selected, the ink drain sequence is executed. It takes approximately 4
minutes for the process to be completed.
7) Check that "Turn Power Off!!" is shown on the display, and then turn off the power.
8) Unplug the power cord from the outlet.
9) Move the carriage, and then takeout the printhead.
10) Replace the following parts
• Ink tube unit : See "Part 5: 5.2.6 Ink tube unit".
• Purge unit : See "Part 5: 5.2.9 Purge unit".
• Ink tank unit : See "Part 5: 5.2.10 Ink tank unit".
11) Turn on the printer, and then continue with the installation operation (from installation of the
printhead). At this time, replace the printhead with a new one*4.
For service manual, You can write me on emma.servis@gmail.com
Hope that helps!
Jul 29, 2011 | Canon W8200PG InkJet Printer
My Canon Image Prograf iPF700 keeps running out of color ink even through all setings are on Black and White (Monochrome). Any suggestions, getting sick of paying for ink im not using.
I you see in the preferences of the printer you have 2 kinds of monocrome( check de advanced option) one uses the all the colors to print in black if you use the second monocrome when you print its not black its more like brown. but this way you dont use de colors inks
Apr 19, 2010 | Canon iPF700 InkJet Printer
E02802
Hi, 1) Power off the Printer.
2) Press and hold the INFORMATION + STOP + OK buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.
If Print Head is replaced without updating firmware, the machine will go into error. In order to bypass this error, CITS (800-423-2366), will ship the L-Printer Service tool CD upon request. This tool will override the error code and allow you to update firmware with the new Print Head.
Regards, polysandy
Apr 19, 2010 | Canon imagePROGRAF W6400 InkJet Printer
Just replaced the printhead with a new one and get error message E02802
are you sure you have placed the right head, this error has to do with wrong head.
Jan 21, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Result very red
is there enough black ink on your cartridge?
try installing a new one.
Jul 23, 2009 | Canon imagePROGRAF W6400 InkJet Printer
Canon printer error problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Jan 07, 2009 | Canon imagePROGRAF W6400 InkJet Printer
Open Questions:
See all Canon imagePROGRAF W6400 InkJet Printer Questions
Canon imagePROGRAF W6400 InkJet Printer Logo
1,454 people viewed this question
old marine
old marine
