Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
COFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
10 CUP GRIND & BREW COFFEE MAKER w/ PAUSE aND !-4 CUP OPTION LEAKS CLEAR WATER FROM BOTTOM WHILE BREWING COFFEE
  • 1 more comment
  • Anonymous Apr 06, 2009
    I always brew 6 cups and it leaks water at the bottom EVERY SINGLE TIME.
  • Sequins55 Apr 22, 2009
    Same problem with our Cuisinart DGB-600BC! A large puddle of water leaks from the bottom on the left hand side. It appears to be getting worse. Any solutions for this?????
  • andrewkstauf
    andrewkstauf Mar 09, 2013
    Yep, here is an image of the underside of our DGB-600BC (bottom cover off) spitting a stream of water out of a corroded spot of the metal heating channel
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Posted on Dec 10, 2010
Just tried fixing water leak in this model. Problem was the red rubber hose connecting to the heater element was split under the retaining spring clip. I cut off 1/2in and reinstalled, but then saw a leak in the heater element tube, caused by corrosion from the previous leak. Tried to seal it with a high temp automotive epoxy (good to 500F), but that did not work as the epoxy became brittle after one use ( must get pretty hot on the element!). So this unit is toast as new element needs to welded into place and is probably not available. Add labor costs and you can buy an new one for less. Bummer. Dr. Fix-it.
Posted on Apr 13, 2015
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee grinder clogging
Remove the grind chamber.
There is a black plastic pice sticking up in the area underneath where the grind chamber would sit. Lift it up, and you will see it is sort of like a hatch. It is probably clogged with coffee grinds.
Go ahead and clear out this chute, and see if it resolves the problem.
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaks everywhere
Make sure the lid is on the caraffe and just try to run plain water through. Although, it sounds like you might actually have a crack/leak. Return to store if possible or call Cuisianrt if it really is leaking.
Dec 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
1,425 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
