Question about Gemini Sound Products P07 2-Channel Amplifier
Gemini p-07 amp board fault
Ihave a gemini p-07 amp which has blown a cap on the board id no c17 as it has destroyed its self i was wondering if you would know what its value is in pf and its purpose and if pos the reason for its failing
Its better to get the schematic diagram or a similar one to be sure, but the reason for a blow up may have to do with a s/c along the line.
Posted on Jun 01, 2007
TV has black screen and Flashlight test fails. I hear a loud beep when power button is long pressed. Power supply to LED strips conn, 1-5 have ~176V but 2-4 have 0V. What might be the issue?
Check and replace its T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 07, 2016 | Samsung UN32EH5300FXZA 32 in. HDTV
Is there a way to make the sound of the reverb on my deville 2-12 sound better ?
modding the reverb takes some electronics experience...if you know where the reverb circuit is. all you can really do is change the input caps that make the tone bright or dull... larger uf for dull... lower cap values for bright... it's in the signal circuits... dont mess with power caps. The schematic shows op amp into the tank and out of the tank to another op amp...Output of the tank to opamp.. Id double that input cap ( 330 pf ) to see if you get more response into the opamp... then look at the circuit C17-C18/R33-R34 894cf4a0-46f7-4f21-9667-be620f05b31d.png
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Jun 06, 2012 | Fender R) Hot Rod DeVille III 212 Guitar...
A friend owns a Mirage LF 150 subwoofer a few years now. Someone had left the volume setting very high on the preamplifier and turned if off. When the preamp was turned on, there was a loud...
You would have blown the fuse. There was a reason why the fuse had blown the first time. Being that this unit is self powered. I would look into the power supply board and look for blown caps. Hopefully you didn't burn the board. Most times a problem like this is a bad Capacitor. Look for blown Capacitors on the board. They will Look like little soda cans. They would be buldging on the top of the cap and possibly leaking yellow or white if bad. Capacitors should be FLAT not having buldge at all. Replace Caps with exact uf EXACT on the Volts you can go over what is printed on the bad Capacitor but never go under. Caps can hold a wallop of a shock and possibly kill you. So either you or a pro discharge the caps. They can hold a punch and knock you on your but. Even unplugged. So Discharge them and proceed.
Dec 26, 2010 | Audio Players & Recorders
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
It just turned off by it self and it wont turn on
TV is in fault protection mode. If the TV relay clicks on then off and the Fault LED starts blinking. You have bad/blown capacitors on the PSB-Power supply board. Recaping the blown UF caps works 90% of the time.
Jun 30, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
My hotpoint wf340 lights are flashing (all of them).
hi, I have the same problem, area around c10 r20 charred and c17 blown. I will change the capacitor on c17 did you change any others whilst working on it? and also which chip did you replace and what did you replace it with?
Oct 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Re: Onkyo DV-CP500 DVD player stuck in standby mode (by 7 users)
Hi Yes, sorry just saw this comment. Swap out C7, C17 and C18 in the power supply. Also I would check if you are getting 9Volts to the motor control IC's pin 7 coming off of C005 on the Mechanism Board which is under the unit. The hole for the C005 cap was drilled into a very narrow section of the circuit board and has marginal connection at best.. mine stopped working because of this 6 months after I fixed the power supply.
Oct 23, 2008 | Onkyo DV-CP500 Multi-disc DVD Player
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
HCN4727W with Convergence issues
Mike,
The ICZ designations on that board are two Sanyo STK392-040 amps used for convergence. Rz142 through Rz145 are the yoke return circuit are 3.9 ohm 1/2w resistors. CZ140 and 141 are two electrolytic radial 22mf/50v caps in the feed circuit for those amps.
My question would be - and I've NEVER seen this, in my 30 years in electronics, what caused such a domino failure? The amps are basically LV fed by a +/- 24v line input. If the yoke(s) were to short shouldn't cause enough feedback to destroy the convergence board in the manner you've indicated here. That's a P58A chassis used in several models of the Samsung and Akai designs. Only trouble I've heard of with those boards are cooling and most techs have taken to installing cooling fans directly on the board, driven by the +/- 20v line. That drops the temp several degrees and allows the amps to operate at a much cooler temp. We rebuild those boards here on a daily basis and add the mods for greater reliability. But other than that the P58A is considered a bullet proof chassis.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Sep 09, 2008 | Samsung HCN4727W 47" Rear Projection...
Maytag gemini self-cleaning oven. I don't have the manual and I'm wondering how to use it.
heres alink to a manual explaining the self clean operation( its for a gas gemini range, but if you have electric, procedure is the same) page 11
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113P383-60.pdf
Mar 22, 2008 | Kitchen Ranges
Gemini Sound Products P07 2-Channel Amplifier Logo
171 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Tom Chichester
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
