I cannot print envelopes using my Dell 3100cn. It will print w/o any problems from the main paper tray, but not envelopes.. I get an error message telling me to load MPF envelopes #10 and Load MPF covers1. However, I have loaded the envelopes. I don't know what Covers 1 is. Help! Thanks...Jerry
Comments:
May 11, 2007
- Yes, I changed computers and the new one has the Vista operating system. The previous computer had the XP system. Were you able to correct the problem?
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem.
Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Was this helpful?
Yes
No
Solution #2
posted on May 11, 2007
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Jerry, are you using Vista? The same thing is happening to me and I used to be able to print, but don't remember if it started happening after I changed o/s
Solution #3
posted on Jun 01, 2007
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
The issue has been resolved. It was not the printer, but the operating system. As was suggested, I hooked the 3100cn up to my old laptop which uses a XP operating system and the envelopes printed properly. A Dell tech walked me through settings adjustments to allow the Vista operating system to work with the 3100cn.
I don't think is going to be particularly helpful, but it seems to be a problem with the printer's MPF tray. I've spent several hours trying to get the thing to work and print to different paper sizes, but it always is a hack to be able to get it to do what I want. I have noticed that if I set the paper in the tray and then go in to the properties dialog in the print menu and go to the "Paper Tray" tab and set the MPF tray to the same settings that it works more often. You also have to set the paper size on the "Paper" tab to what you are expecting. I don't know why Dell's drivers aren't capable of handling all of that more elegantly, but it seems to be a common complaint.
Can't fill the paper tray up to the fill line. Dell 3100cn says "paper jam," although of...
(More)
Can't fill the paper tray up to the fill line. Dell 3100cn says "paper jam," although of course there is none. Can maybe get in 1/4 of the paper it is supposed to hold...any ideas why? The roller seems to be fine, and we've cleaned it. Thanks!
I have a dell 3100CN with a duplexer on it...alof a sudden I am getting a "close reg...
(More)
I have a dell 3100CN with a duplexer on it...alof a sudden I am getting a "close reg cover" message...the reg cover is closed....what should I do? Mark
trying to print microsoft excel spreadsheet printer keeps saying load tray A4 both trays have paper...
(More)
trying to print microsoft excel spreadsheet printer keeps saying load tray A4 both trays have paper whats going on
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
