Question about Panasonic PT-44LCX65 Television
Panasonic TV works for 10 mins or so then promps a Air Filter needs cleaning. How do I do that? Thanks, Bob
  • 585 Answers
The air filter should be a user-accessible thing. Consult your owners manual for details. Can you find the manual?
Posted on Jan 18, 2009
Air filter need service and tv shuts off after 1 min. I have attempted to clean all the dust from the tv by removing the rear cover and using shop air to clean. I am wondering wether this is going to be...
I have the same problem with my 50" panasonic PT-50LCX64 tv. I have a call into a technician to see if it is going to be a cost effective repair, I am very unhappy with their technical support. I also have removed the bace and cleaned everything back there and blew it out. Their techs. say it is an internal filter that has to be cleaned by a service center or dealer. They will not say where the filter is at so I can clean it myself.
Feb 05, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-60LCX64 Air Filter Cleaning
Cleaning filter for the Panansonic PT-501LCX64.
I just had a T.V. tech do this. The filters are located on the two removable filters on the back side of the T.V. They look like the speaker units. He removed those two units, unplugged them & set them on the floor. He took some type of electronic cleaner with a cloth & wiped them down. The filters themselves are plastic. He explained that air flows through some tube connected to these plastic filters for cooling down below. He admitted they didn't look dirty--put everything back together & it is working fine now.
I imagine that dirty or not the timer is automatically set for every 400 hrs. of use to give you the prompt that the filter needs cleaning & will shut off in one minute so you can call a T.V. tech?
So to reset the timer--follow the other detailed prompts listed on this board & or use your owners manual & follow the prompts for replacing the bulb. That should take you somewhere to reset the timer--so you have another 400 hours of operation.
I believe it's with the T.V. turned off--hold down the down volume on your tv itself while holding the swap button on the remote control for 5-7 seconds---then follow the prompts. You should see a prompt for replacing a bulb & then one for filter cleaning. Then just reset the timer.
Hopefully this will help?
Nov 04, 2008 | Panasonic PT-60LCX64 Television
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air filter error message
remove all the screws from the lower panel the ones with the arrows , after all the screws are removed the lower panel should come out , in the very center of the tv inside you will see some wires in front of a black plastic cover about 6" X 3" .carefully move the wires out of the way by moving them down . after the wires are moved get a phillips screw driver with a magnetic tip memove the screws from black cover be very carefull not to drop the screws into the tv . after the screws are removed carefully pull the black cover off . under the cover youll see the "AIR FILTER" carfully pry the filter out i used a butter knife .
take out the filter and blow it out using light air pressure. the filter may look clean but its not ,check it by putting a flashlight on the filter and looking through it before and after . to reinsstall just reverse the process.. before i discovered this i called panasonic directly they stated i had to take it to a authorized service center, i called a center and they said $350.00 for a house call and 250.00 if i brought it to them .
good luck i hope i saved you some money !
Jul 12, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Filter cleaning issue
Try making sure that your cable box is turned on (if you have one) then try the volume down button (on the tv) at the same time as the tv/video button (on the remote).
If that works please post back about how you got past the first menu that does not allow you to reset the air filter hours...
We have the same issue and we cannot get past that menu.
I don't think we have an air filter???
Jan 10, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Air fitler cleaning
REMOVE THE BOTTOM PANEL OF THE BACK OF THE TV. CLEAN OUT PANEL WITH WATER AND DRY.(IF NOT DRYED OUT PROPERLY CAN CAUSE SHORT) CLEAN OF THE FAN ON THE BACK RIGHT SIDE (REMOVE ALL DUST) THEN REINSTALL BACK PANEL. TV SHOULD WORK
Nov 07, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-44LCX65 Television Logo
407 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
