Question about Whirlpool LGR7646E Dryer
Whirlpool Supreme Dryer will Not Start
Dryer will not start. Light is on inside dryer. Any suggestions on what to check first.
Model No. LER7646EQ2
Type No. 178-00
Serial No. MH3981823
  • monkeyxu Feb 24, 2009
    Dryer has heat and sound when timer is set and started but failed to rotate.
    Model: LER7646EQ2
  • N5anyer Apr 29, 2009
    Set he timer knob and push the start button and nothings happens.
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Posted on Jan 27, 2009
Whirlpool supreme LER7646EQ2 won't heat up
The heating element is no good. They break after years of use as they heat up and cool down over and over, they wear out. The part is cheap and yes it is easy to replace. Turn your dryer around, and take off the screws to a short piece of metal that has "vents" in it. It should be sticking out a bit compared to the rest of the dryer back. normally 2 or 4 screws holding it there. You'll see the element. Just pull it out, take it to the appliance shop or Sears and get another element. Go home, stick it back in there and reconnect the panel you took off. Cheap part, simple fix...you'll be surprised how well it heats after that.
Jun 09, 2012 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model #LER7646EQ2 dryer will not start up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2011 | Whirlpool Dryers
Dryer will not turn on,timer is counting down. I do not have a fuse problem, can you give me possible reason. We just finished a load of wash last night. ...
heatman101
Apr 30, 2011 | Whirlpool Dryers
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer screeching and grinding when running
Hi !
The drive belt has become old and hard.
Just change the drive belt and all will be well.
Please don't try to lubricate the belt as may be suggested by many as cheap quick fix.
Regards
Berry.
Feb 01, 2010 | Whirlpool Dryers
No heat in electric dryer model LER7646Eq2
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail in your dryer are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open.
Aug 25, 2009 | Whirlpool Dryers
Been working fine and now won't start.
Hi friend.
it mostly be the motor problem itself or,,,,see anything stucked below tub it will also cause problem.check it
thank u,,,,,,,,,
May 03, 2009 | Whirlpool LER7646E Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
810 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
