Question about Inter-Tel Intertel 6123300 GLX Executive Phone
I need my phone to ring at my desk
I want the phones to ring at certain desk and not all . I cannot remember how to do so.
  • amih May 11, 2010
    Are you still needing to complete this? I can provide instructions if so.
Turn the program toggle switch on (right side of KSU), go to the phone to be programmed and press the # button, then press the line button to ring, then pick up and then hang up handset. You should hear a confirmation tone. This will affect all line buttons, even the ones not pressed. Any line buttons not pressed will not ring. Do this at each phone.
Posted on Jul 24, 2009
M try to call desk phone but is ringing no loud
Firstly we need to check if the problems is with the phone or the phone line itself, try plugging a known working phone in to the wall socket and ring it, if the phone rings the aloud the problem is with the other phone if the phone doesn't ring the problem is with the phone line its self and an engineer will need to investigate further, Lets assume the problem is with the phone itself:
Providing you are dialling the correct number and desk phone is switched on, then two things spring to mind, either the phone has been set to silent (I would need both the make and the model to do a walk through on how to turn the volume up) or the speaker for the ringer has been damaged and the phone needs replacing.
May 05, 2014 | Panasonic Lands Phones
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
My new job has a Lucent phone and it does not ring at my desk. The only phone I hear ringing is two doors down from my office. Please help me program my phone to ring at my desk. I all ready tried the...
1.) Are you refering to outside lines ringing?
2.) What if someone dials you on intercom does it ring then?
If #1 the phone SYSTEM usually has an option that you have to program and add you to the ring pool for the outside lines.
If #2 does not ring it is also a function to disallow ring, but it very well could be the phone. Since the line is all that matters and NOT the phone, you could try another phone at your location and see if the same happens. If it does, you will need to program the SYSTEM from either Ext. 10 or 11 to add you to the ring pool and allow ring.
Apr 28, 2010 | Lucent PARTNER18 Corded Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
How to change Auto attendent Dial O to ring at multiple ext
First you will need to add extensions to a group X in #502
When you login to administrative mailbox you will change you operator extension to 7X. Phones in the group will ring
Apr 22, 2009 | Avaya Lucent Partner 616 Phone
Trying to Transfer a Line to Ring at anothers desk after 4 rings.
When my boss is on the phone she wants all incoming calls to bounce to my line. or ring so she knows an incoming call is coming. what can we do?
Aug 29, 2008 | Mitel Superset 4025 Corded Phone...
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
Inter-Tel Intertel 6123300 GLX Executive Phone Logo
342 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
