Question about Maytag PYE2300AY Electric Dryer
Dryer will not run -- can hear timer working but nothing else goes on -- power is good --
  • 1 more comment
  • Anonymous Jan 01, 2009
    My Maytag pye3300ayw worked fine until today. Turned on and ran great for 20 minutes. Stopped and can't get it to work. Any thoughts ? Power is good with no breaker issues. No wires are loose on the switch area on top as I opened it up and looked..
    My Maytag pye3300ayw stopped working today. Ran for 20 minutes and then nothing. Power issues are fine with no breaker tripping. I took the top console aprt and all wires are connected. MAin switch feels right just will not work. ANy thoughts ??
  • mchenry_juli Jan 02, 2009
    Dryer runs for about 15-20 seconds then stops... I can still hear the timer running though.
  • 163 Answers
Recall alert check.call sears and ask to see if there is a recall on this model and brand of dryer..
Posted on Jan 03, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Dryer will not turn on -- i can hear the timer working -- but nothing goes on when i push the timer
check the door switch and make sure it is working properly. You didnt specify gas or electric.
Dec 30, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Dryer won't run
Maytag Atlantis Series MDE6400AYW --
Current is good, brand new power cord, drum light comes on --
When I turn the timer, I can hear it clicking, but nothing else works.
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
90 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
