Question about Sharp AL 1215 Black and White Copier
My copier makes a noisy sound
Every time I turn my copier on, it makes a loud chainsaw-like sound. It seems like a gear got stuck and it feeds paper only halfway and crumples away before it reaches the drum area.
    Problem Solver:
  • 6 Answers
Could be gears or also a piece of paper in fuser causing a jam that is stopping the fuser from turning also check the "fingers" are not stuck up or are off their springs
fingers help separate paper from the roller but can cause jamming if not in correct position
Posted on Dec 04, 2007
    Problem Solver:
  • 18 Answers
Paper pickup clutch spring slipping, cause by toner leaking from toner unit. strip and clean clutch spring or replace.
Posted on Oct 08, 2007
    Scholar:
  • 77 Answers
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
Posted on May 02, 2007
Broken plastic gear in lower paper feed
That sounds like a fairly simple fix - using your printer's model number, do an online search for replacement parts. If you're fairly handy, you should be able to do the job yourself. If you have a friend or relative who's handy, they should be able to do it. A typical commercial shop will probably charge quite a lot of money (possibly more than the price of a replacement printer) to do the job.
Jul 22, 2014 | HP PhotoSmart Office Equipment & Supplies
Paper wont feed
Could be a piece of paper stuck somewhere, open all access areas and check carefully, sounds like an obstruction somewhere
Apr 01, 2014 | Cannon i70 Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
Why the paper get stuck while copying, and the machine make a loud noise
it may be feeding from the wrong tray. i was trying to copy short paper and it was feeding from the long paper section. this caused it to stick ever time. make sure the machine is feeding from the right tray.
Jan 23, 2010 | Sharp AL-1655CS Copier
Not feeding paper very noisy whin it tries shoes to be jammed
You could have a paper jam that's jamming the gears that turn to feed the paper. Make sure there's no paper inside jamming up the roller bar. The other possibility is that you have a stripped gear, that is chattering when it tried to drive the paper feed roller.
http://welcome.hp.com/country/us/en/support.html
Make sure you get an estimate if you get it repaired, since the cost of repair can often justify just going ahead and buying a new one.
Good luck, and hope this helps.
Jan 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Jan 19, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Pixma mp830
Take it back for a full replacement, it sound like it has a few faults, why be stuck with it, you have the right to fair trading, which states your product must do wahta it should for a reasonable amount of time. Just out of box and faulting already is not reasonable!!! Hope you hace receipt.
Aug 31, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Sharp AL 1215 Black and White Copier Logo
152 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
