Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Tl Spin settings
When we start a load of laundry in the washer, the spin setting will start to change itself and not stop. It happens for about 1 minute then will stop and then a minute later continue to change itself. Is there anything that can help or do we need to get a new washer?
  • 4 more comments
  • jonathantyle Jan 06, 2009
    I think I have the same problem. On my washer, the lights on the spin section will cycle from low to med to high to max extract over and over again. I can't get it to stop doing this. However, the washer will (sometimes) allow me to wash a load of laundry. Sometimes, the washer will turn itself on and do the spin cycle thing. Any help for a possessed washer? :)
  • Kacie_Austin Mar 16, 2009
    Obnoxious beep beep beep. The control panel buttons don't respond while it is in "the spin cycle meltdown". Can't turn it off. Cut the breaker to possibly reset control panel, but to no avail. Read the below instructions for DIY repair and membrane check. Will attempt. Thanks for the help. For the record I agree that this machine was faulty and this is the second repair necessary since 2005. Word to the wise heard about class action lawsuit against Maytag specifically regarding this model (neptune TL). Call 888. 462. 9824 and listen for info about lawsuit if interested. Hope this helps some other poor soul that purchased this item in good faith. Down with the conglomerates.
  • mgrey Apr 16, 2009
    Washer acts normal but the spin setting on the console will begin rotating through the cycle back and forth.....sometimes the washer will complete the wash, then it might go back on by itself. I saw some solutions on doing a check on the membrane, I will try this. Also something about Pins 4 and 5 on the board or ribbon connector - I will look at this also. If any other solutions are out there, let me know. I just fixed one problem on the machine and this started 3 days later.
  • tminutes Apr 23, 2009
    I have the same problem as Jonathan Tyler
    " On my washer, the lights on the spin section will cycle from low to med to high to max extract over and over again."
    It seems that lights cycle when washer is changing from wash to rinse to spin. Once on spin it keeps cycling the lights & beeps. So a 60 minute cycle is on 75 and not done.
  • jonathantyle May 11, 2010
    OK, I tried the Membrane Switch Check and everything works... except the Spin membrane. That button did nothing during the test, but all of the other buttons worked fine. This washer is about 5 years old and the problem started only about three months ago.
  • onthethejob1
    onthethejob1 May 11, 2010
    what do you mean the spin setting,,,do you mean the timer,,???more detail please
HELP I HAVE THE SAME IS ISSUE AS\r\n
http://www.fixya.com/support/t1457953-maytag_neptune_tl_spin_settings
My Spin cycles keep cycling through, it seems to wash fine but is always beeping and changing through the spin selection.
Is it the control board, ribon cable, membrane??
HELP!
Nate
Posted on Jul 24, 2009
  • 335 Answers
I would try verify that the spin cycle membrane key is not stuck/defective signaling the controller to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test to get a start point.
Do you have the troubleshooting guide stored in the control panel? It was shipped with the machine, pull 120VAC washer power plug, remove the top three torx screws at he top back of the control panel and remove the trouble shooting guide. Rassemble and power up your machine. Follow the instructions for Membrane Pad Test. You will enter Service Mode to verify that the key pad function LED can be toggled, just press each key once except the Presoak key as described below. If you don’t have the Troubleshooting guide that came with your FAV6800A I have pasted in the test from the SM;
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin
Only keys for three seconds or until the control beeps.
Membrane Pad Test
While in Service Mode, pressing the Presoak key will
start a membrane switch check that verifies switch
operation. All the LEDs (except Presoak ) can be toggled
or slewed by pressing the key associated with the LED or
set of LEDs. Each time either set delay arrow is pressed
the digits toggle between a blank and 8. All keys
(including the OFF button) must be pressed within 5
minutes for this test to pass. “PA” will be displayed for
five (5) seconds once all keys have been pressed and the
test is completed. Following 10 seconds of inactivity at
any point, this test will exit without any display.
Let us know your results.
Posted on Jan 11, 2009
  • 3 more comments
  • dh1200s
    dh1200s Jan 12, 2009
    Hello jonathantyle,
    I feel this is a repairable situation with your machine but further fault isolation/troubleshooting of the Membrane Pad, the ribbon cable connection to the control board or a failed function of the control board are required. My best guess is a hard short or corrosion bridge between pins 5&4 of the of ribbon cable of the Membrane Pad, my second guess is a corrosion bridge at Pins 5&4 at the socket connection on the control board. Caution do not make any ohm meter readings on the control board, that could possibly destroy the control board. Your supplied troubleshooting guide will show you the pin outs of the Membrane Pad, and continuity checks associated with the key pad if you want to try a DIY repair. If the continuity checks test OK I would replace the control board and hope for the best. If you feel uncomfortable with a DIY repair I would turn to qualified Service Repair Company.
    This site can point you to parts suppliers or Google Maytag FAV6800A parts, The Membrane Pad and controller board are around $190 each.
    I’m a DIY’er and not a Service Tech, I had problems with the Clutch in this machine causing dc/UC error codes in spin cycle and did a DIY repair (WD-40 lube of clutch bearings) after visiting this site and many others for a repair solution. My machine was purchased in 7/05. I did contact Maytag Customer Service about what I felt was the early failure of this machine, the 1st level service rep offered me 15% rebate on the purchase of one of their products. I then asked to speak to a supervisor and was offered 25% rebate. I chose the DIY repair solution.
    Good luck
  • dh1200s
    dh1200s Mar 16, 2009
    Hi Kacie, I’m very sorry to hear about your issue. To make sure I understand the issue you mentioned “”control panel buttons don't respond while it is in "the spin cycle meltdown".””. Did you make it to spin cycle while running a normal wash load? After a power up power down (breaker reset) you can’t get into any Wash Cycle or Spin Only Cycle is that correct? If this is so then I don’t believe you will be able to get into Service Mode by pressing the Enviro Plus and Spin Only keys for three seconds or beeps. I would guess from here that the control board has failed but let us know if you can get into Service Mode. Do you think you may have haad a power surge caused by a recent storm activity? Let us know what findings you come with.  We will try to help, take care and good luck to you.
  • dh1200s
    dh1200s Apr 19, 2009
    Post to jonathantyle if you are still around. Did you ever resolve your issue with the Spin function key cycling thru the settings? If you did can you share with us what the fix was. Thank you Rich
  • dh1200s
    dh1200s Apr 24, 2009
    Hello tminutes,
    This could be a difficult problem to troubleshoot as you can tell by the lack of technical response. If it's not an issue with the Spin Select Key or corrosion at the connector plug and ribbon cable then I would guess it's an issue with the control board. The control board is under warranty for 5 years. I will try to work with you if you want to go forward with further troubleshooting and a possible DIY fix. Rich
    The Service Manual for reference. Sears Parts Direct for reference.
    Question to mgrey Have you made any progress on this issue?
  • dh1200s
    dh1200s Jul 29, 2009
    Nate,
    I missed your post I did not look at comment posted as a solution. Are you still having this issue? This issue I feel will be difficult to troubleshoot but I will try to help. You should post as new issue. I have seen several of these post with no real feedback from owners as to issue status. Open up a new problem and lets go from there. I'm an owner like you and if I can't help maybe a appliance repair folks will chime in on this issue. An issue such as this may require troubleshooting with an OHM Meter on the console membrane key pad. Would you want to troubleshoot? Let me know.
    Rich
Ribbon connection from the membrane pad to the control board will fail (designed to) the connection ribbon flops around while the washer runs and eventually breaks the connections in the ribbon. Its made of some weird material but is repairable with some fine wire and sewing stick pin needles ;-) solder a pin to the each end of a small gauge wire and stick it through the material on each side of the break. The break usually happens right where the ribbon connects to the membrane pad. It can be hard see sometimes. $174.00 is the cheapest replacement I could find. I have had mine rigged like this for over a year but more connections keep breaking so I am gonna get a replacement soon ;-(
Posted on Dec 10, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washer stops after starting the spin cycle
Google "Sticky: Neptune TL Washer FAV6800AWW"
You can get the Service Manual from that site 5 post down. At that post I discuss how to DIY the fix.
Feb 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL (FAV6800AWQ , Serial # 10178127EC) that starts and stops after the wash cycle begins. It fills up fine but starts and stops/pauses and the time doesn’t lapse. On a normal load...
You have a Series 10 machine 1st two digits of your s/n.
Seems like you have the Service Manual or troubleshooting guide.....can't get that from Servicematters any more I feel you have some drive system binding.
I helped a owner on another forum similar problem. Google this "Neptune TL Spinning Issue Will Not Proceed". Did a lot of up front testing in the end he ended up replaceing the Outer Tub Bearings, the Clutch Pulley.
Start by opening the washer lid and see if you can rotate the wash basket with one finger in the CCW Spin direction. There should be only slight resistance to rotate the wash basket CCW. During the 1st water fill of the wash basket the Control Board will spin the wash Basket slow rpm you can enter Service Mode and observe the rpm on the LED console.
Next start a Quick Spin test and note the highest RPM range the machine will spin up to. Looking for Outer Tub Bearing resistance.
I would suggest another DIY forum to work thru this issue if you are going to DIY. This forum is hit and miss we posting pics and e-mail notification for support......Rich
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune front load washer will not spin this has happened before and I called service they held down some button where the start wash etc are on on top of the washer. It washed the load but when...
Check whether water is fully drained. Since the motor worked during wash motor is not faulty.
Check relay that poers the motor during spin mode. May be micro controller fault posiible.
Mar 31, 2010 | Maytag Neptune MAH6500A Front Load Washer
Neptune tl washer will go half way threw cyle,start to spin,stop and start to spin,stop and start to spin .tried to unplug it restart and nothin, tried different settings still nothing. tried moving the...
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If it one of those machines I suspect a possible clutch malfunction.
See this post for what is involved to do clutch maintenance or replacement.
Do you have any error codes to the display if it's a FAV6800A such as dC or uC unbalance codes. Is the wash tub banging around on Spin Cycle of the Wash Cycle? ……Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL won't spin, continuously beeps through spin settings
if water remains in the tub it will not go into the spin cyc something in the pump clear it and try again
Aug 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Spin Option
The problems posted by kim875 and kirsty2 all seem to be the result of faulty signals from the electronic board. This seems to be a real problem with this model machine. I would try to get board replaced under warranty , if at all possible.
Dec 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
