Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
Standby mode I have a Sylvania 6842PEM, every time I press the power, it switches back to standby mode
  • 1 more comment
  • Jonzi Nov 21, 2007
    My tv always swicthes back to standby mode whenever I turn it on
  • kedoedecker Jan 23, 2009
    Hit power and it just goes back to stand by...it's only 2 years old. Is Sylvania producing ****?
  • Anonymous Mar 28, 2014
    No power after turning on power switch
It happened to me.. a FAx to Enrique. in California.
Posted on Jul 12, 2007
I have a sylvania 6842pem very time i press the power, it switch back to standby mode
Posted on Jan 04, 2009
It is probably your SS board. I had the same problem with a customer unit. You must make sure you get the right board because there are 3 versions of this unit. All Panasonic parts as well :/
Posted on Jul 09, 2008
I too have this problem on a new Sylvania, when I called tech support they told me I would have to fax my receipt to Enrique and he would get back to me in 3-5 days!!!!!! No last name just Enrique. Well I did that and I have yet to hear from anyone. Hopefully someone here can help? Please!!!!!!
Posted on May 18, 2007
Getting sylvania scr1986bt-as in standby mode
I think I cracked the code on this inexpensive but potentially infuriating little clock.When you first plug it in, it goes into STANDBY mode (identified by flashing ":" in the time display). In this mode, you set the time, alarms, preset radio stations, etc.
Once these are set, you go into NORMAL mode by pressing the SOURCE button (in the back row). In NORMAL mode, the : in the time display is steady. In different modes, the middle row and front row buttons do different things.
To return to STANDBY, you have to unplug the cord briefly and plug it back in. In STANDBY, the (front row buttons) AL-1 & AL-2 allow you to "cycle through" [buzzer-radio-off ] options for each alarm , and alter the time setting for each alarm (middle buttons). Once set, just wait and it will accept the new setting and display.
In NORMAL, the front row buttons raise or lower the volume of the radio. CAUTION: if you chose the radio setting for an alarm, and set the volume to 0, it will not wake you up! The middle row buttons only do anything when the radio is playing (SOURCE in the back row), when they can be used to tune the radio up and down, or move to preset station. Note that the SOURCE button is also used to select Blutooth sync, indicated by the blinking Bluetooth light on the right side of the display. To stop this from blinking, press SOURCE until AU (for auxiliary) appears and simply wait until it returns to NORMAL display.
Hope that helps.
Oct 08, 2017 | Sylvania Televison & Video
Silvanya LC321SS9 B standby led... wont turn on
Could be an open internal fuse or power supply failure
Nov 18, 2016 | Sylvania Televison & Video
Setting clock on Sylvania SCR4986
This is what i found:
Clock Setting
The clock can be only set while the unit is in standby mode
1. While the unit is in standby mode, press the TIME_SET button into clock setting. The LED
display will start flashing, press REV/DOWN or FF/UP to select 12h display or 24h display.
Confirm your setting by press TIME_SET again
2. While the unit is in standby mode, press and hold the TIME_SET button for 2-3 seconds, the
hours will start flashing, press REV/DOWN or FF/UP to set the current hour, press the
TIME_SET button to confirm the setting, then the minutes will start flashing, press
REV/DOWN or FF/UP to set the current minutes, press the TIME_SET again to confirm all
setting. The time is now set
Drew.
Jan 14, 2015 | Sylvania Audio Players & Recorders
Sylvania tv manuals model lc195sl9
http://www.searspartsdirect.com/partsdirect/user-manuals/lc195sl8-sylvania-parts-tv+lcd-manual [] Control Panel
POWER (pl 1)
Press to turn the unit on and off.
INPUT SELECT (pl 3)
5. SETUP (p11)
Press to display the main menu.
6. infrared sensor window
Receives infrared rays transmitted from the remote
control.
7. power on indicator
Lights up when power is on.
8. standby indicator
Lights up in standby mode.
May 02, 2014 | Televison & Video
My sylvania tv is stuck on standby
This is due to a bad power supply system which consist of an electronical board with capacitors on them that burn out.
Jun 18, 2012 | Sylvania Televison & Video
I have a 19 inch Sylavnia HDTV (Model #LC195SL9 B - 120 V~60Hz 55W) and have had it less than a year. All of a sudden the TV will not go into standby mode and the TV appears "ON" all the time. I do not get...
Sylvania 6419TE
The issue is the powerboard is not going into staby mode, unfortunatly this will need repair if its under warranty this repair would be covered. Now there is no real issue here if it does not go into standby but to save on those eletricty bills i would simply unplug it anyhow. The issue and reason why products have a stamdby mode is for auto timers and record timers things like that. What happends is the power supply inside is not going into its standby mode and the reason behind this is a defective relay.
I could get techincal and down to componet level but I will loose you in the tech mist. Quite simple here get it repaired or deal with it until it finally goes out. The power supply is on its last leg.
This was a free answer provided in part by Fixya.com please be considerate and rate and leave feedback to help pay the bills here (keep the lights on) Expert does not get paid just by cash the ratings help him stay into his expert status.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 29, 2010 | Sylvania 6419TE 19" TV
Tv turns on and then right back off
it sounds like one of the boards are going out I would call sylvania and check with there service dept maybe they can send a tech and part out under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Hi I have a sylvania 6842pem 42 inch plasma. when turning the television on it makes a weird screeching noise then goes to stand by. what can the problem be thanks for the help
your transformer on your power supply is bad, i would recomend replacing the power supply, usually when the transformer goes bad , it damages other things on the board, should be around a 200$ part
Jan 11, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania Power Board
I had the same issue. Turned out to be a blown capacitor on the power board.
<a href="http://s133.photobucket.com/albums/q68/rwlib3/?action=view&current=DSC_0426.jpg" target="_blank">
Jun 15, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
917 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
