Question about Linksys Wireless-G WRT54G Router
Linksys router will not reconnect after rebooting modem
I can set up my linksys wrt54g v1.1 to connect to the internet and work fine but after rebooting the modem. it will not reconnect to the modem untill i go through the set up procedure again. if working directly from the computer to the modem everything is fine. i have checked the ip address on the computer and and on the linksys they seam to remain the same even after rebooting. here is the last conversation i had with the online support at linksys.
terry taylor: wrt54g v1.1 [08:42:48 AM]
terry taylor: cdc20cb58103 [08:43:22 AM]
Hans S. (10552): Thank you. [08:44:06 AM]
terry taylor: cdf20cb58103 [08:43:46 AM]
terry taylor: sorryu typo [08:43:51 AM]
Hans S. (10552): Thank you. [08:44:44 AM]
Hans S. (10552): Is your computer wired now to modem? [08:44:52 AM]
terry taylor: yes [08:44:25 AM]
terry taylor: i have been through thid with another tech [08:44:43 AM]
terry taylor: but what im wondering now [08:44:56 AM]
terry taylor: my computer connects with usb also to the modem [08:45:20 AM]
terry taylor: is it possible to set the router to connect through the computer [08:45:49 AM]
Hans S. (10552): Terry, when you have a router. You have to disconnect the computer from the USB connection and connect the computer to the port 1 of the router. And the cable from the modem should be connected to the Internet port of the router. [08:47:04 AM]
Hans S. (10552): Your modem has an Ethernet port, right? [08:47:10 AM]
terry taylor: yes [08:46:47 AM]
terry taylor: i did [08:46:49 AM]
terry taylor: this [08:46:52 AM]
terry taylor: it was set correctly [08:47:00 AM]
terry taylor: your rep told me that she thought the router was bad [08:47:24 AM]
terry taylor: but it worked fine when i had a switch between the router and the modem [08:47:56 AM]
terry taylor: but i do not have the switch any more [08:48:18 AM]
Hans S. (10552): Let's check first the IP address of your computer. Please click on Start. Click on Run. Type in CMD and hit enter. On the black screen, type in ipconfig and hit enter, then please tell me the IP address, subnet mask and default gateway. [08:49:11 AM]
terry taylor: before or after conneting to the router [08:49:11 AM]
terry taylor: when connected through the router it is [08:49:34 AM]
terry taylor: 192.168.1.1 [08:49:41 AM]
Hans S. (10552): Before connecting the router. Check the IP address of the computer that you are using right now. [08:50:21 AM]
terry taylor: 255.255.255.0 [08:49:52 AM]
terry taylor: 192.168.1.1 [08:50:05 AM]
terry taylor: if connected directly to the modem it is [08:50:27 AM]
terry taylor: wowway.com [08:50:41 AM]
terry taylor: 67.149.39.158 [08:50:53 AM]
terry taylor: 255.255.248.0 [08:51:02 AM]
terry taylor: 67.149.32.1 [08:51:20 AM]
Hans S. (10552): Thank you. [08:52:00 AM]
Hans S. (10552): Who's your Internet Service Provider? [08:52:09 AM]
terry taylor: wowway [08:51:41 AM]
Hans S. (10552): Is your ISP Cable or DSL? [08:52:27 AM]
terry taylor: they of no help to me [08:51:55 AM]
terry taylor: yes [08:52:00 AM]
terry taylor: cable [08:52:04 AM]
Hans S. (10552): Okay. [08:52:56 AM]
Hans S. (10552): Since connecting the router now to the modem will disconnect our session. I will give you the steps on how to properly configure your router. Copy the steps and do them after this session, okay? [08:53:28 AM]
terry taylor: To set up your Linksys router for cable Internet, you need to reset the router, connect the devices, and then do a power cycle. I. Reset the router. 1. Press and hold the reset button for 30 seconds. 2. Unplug then plug back the power adapter to the power source. II. Configure the router. 1. Connect a computer to any of the LAN or numbered ports of the router. Use the computer that can access the Internet when connected directly to the modem. Disable the firewall on the computer. The modem should not be connected to the router yet. 2. Make sure that the corresponding LED for the numbered port is lit. (The modem should not be connected to the router yet). 3. Double-click on Internet Explorer. 4. When Internet Explorer opens, type the IP address of the router (by default, http://192.168.1.1) on the Address bar and click on Go. The log-in window will appear. 5. Skip the User Name field, type admin (the default password) on the Password field, and then hit Enter. 6. Under the Basic Setup tab, the Internet Connection type should be set to Automatic Configuration-DHCP. 7. Click on the MAC Address Clone sub tab, select "Clone your PC's MAC," and then click on Save Settings. 8. Connect one end of an Ethernet cable to the modem's Ethernet/LAN port and another end to the router's Internet port. Your computers should be connected to any of the LAN or numbered ports. 9. Click on Status and check if you have Internet IP Address. If yes, then you should be able to access the Internet III. Set up the wireless network. 1. Click on the Wireless tab. 2. Set the Wireless Mode field to Mixed. 3. On the Wireless Network Name (SSID) field, remove "linksys" and type any name you prefer for your wireless network. 4. For a wireless G router, change the Wireless Channel to 11. For a wireless N router, set the Radioband to Wide, the Wide Channel to 9, and the Standard Channel to 11. Or you may set the Radioband to Standard and the Standard Channel to 11. 5. Enable the Wireless SSID Broadcast and then click on Save Settings. 6. Click on the Wireless Security sub tab. If you want to enable WEP: a. Set the Security Mode to WEP. b. Set WEP Encryption to either 64 bits 10 hex digits or 128 bits 26 hex digits. c. There are two options for creating the network key or the password for the wireless network: ** Use the Passphrase field to generate the keys. Click on the Generate button so that the key fields will be populated. If the Default Transmit Key is set to 1 then the value on the Key 1 field is your network key. ** Create your own key by leaving the Passphrase field blank. If the Default Transmit Key is set to 1 then type your network key on the Key 1 field.You may use numbers or letters A to F. You may create a combination of letters and numbers If your WEP Encryption is 64 bits then your key should be 10 characters in length; if it is 128 bits, then your key should be 26 characters in length. d. Click on Save Settings. IV. Power cycle. 1. Shut down the computers. 2. Unplug the power cable of the router, followed by the modem. 3. Wait for one minute. 4. Plug in the Broadband modem’s power cable and wait for the lights to stop blinking. Then plug in the router's power cable. 5. Finally, start up the computers and test your Internet connection. [08:53:50 AM]
terry taylor: these are the steps i followed [08:54:05 AM]
Hans S. (10552): Please hold on. [08:55:08 AM]
Hans S. (10552): After following the steps, did you disconnect the USB cable from your computer that is connected to the modem? [08:55:53 AM]
terry taylor: yes [08:55:32 AM]
terry taylor: the system will configure with out the usb connected [08:55:50 AM]
terry taylor: i reset the system ithout the usb connected [08:56:11 AM]
terry taylor: and the system worked till i rebooted the modem [08:56:34 AM]
terry taylor: then i have to start the whole precedure over [08:56:47 AM]
terry taylor: if the computer is connected to the modem with out the usb everything is fine [08:57:18 AM]
Dude,i have the exact same prob
Posted on Dec 30, 2008
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Wireless-G WRT54G Router: I lost internet connection from router. Everythin...
Unplug both router and modem. Disconnect modem from router. Wait 5 mins and reconnect everything.
May 18, 2010 | Linksys Wireless-G WRT54G Router
I just starting using this wireless router and when I set it up the router software keeps saying I don't have a connection to the internet but I'm on the internet on that computer right now. ...
Make sure that there is not direct connection between your desktop and modem ( USB ). If there is any USB connection from the modem to the computer then it will go on linee but the router will not be on line.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect thru linksys router to internet. I can connect with direct cable but when connected to linksys does not connect.
Mar 17, 2010 | Linksys Wireless-G WRT54G Router
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G not connected to internet.
YOU NEED TO CALL THE 800 # FOR LINKSYS AND THEY WILL CONFIGURE THE ROUTER WITH YOU FOR FREE OVER THE PHONE JUST HAVE PATIENCE THE TECHS ARE INDIAN.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
Connection drop-outs
Is your laptop wireless adapter a compatable brand. It doesn't necessarily mean the router is bad, you may even be getting RADIO interference from a cordlees or a cell phone in it's path. Do you have the capability to plug a cat-5 cable directly into your laptop from the router when you lose wireless? Check the wireless channels and see about changing the channel on your cordless phone too. May not work, just a hunch.
Good Luck
Mar 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
379 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
