Question about Konica Minolta DiALTA Di200 Copier
Minolta Di 351 code C0500 & need reset code for this
I believe it happened after a power failure. I need the codes to reset the warm up phase (I believe) for this. Is there someone that knows how to do this?
Does anyone have a tech manual for troubleshooting. Really in a bind.
I also don't have the admin code. Does anyone know how to reset this also. I own it from my previous business, but lost the codes in a move. I appreciate any input. Thanks.
  • cvachon Dec 31, 2008
    I have tried the small hole on the side. I hit the 3 when I see the dot come up on the left side, but it goes to a screen that looks like it wants me to input a code. The only other thing on the screen is an "end" button. I can put some numbers in, but I don't know any admin code or even where to push an "enter" button. Familiar with this one? Thanks.
  • 145 Answers
Look for a small hole...on right side of the disply panel...THE HOLE IS SMALL THE SIZE OF PAPER CLIP IN DIMETER..IN FACT THE ONLY WAY TO ACCESS IS BY PAPER CLIP.PRESS IT ONCE VERY GENTLY..AND WAIT FOR A SMALL DOT TO APEAR ON THE LEFT SIDE OF THE SCREEN IN THE CENTER.ONCE YOU SEE IT>>PRESS # 3 than you will be promted by a screen to reset troublr code press it to conform MACHINE WILL RECYCLE
HOPE THAT HELP S
GOOD LUCK
Posted on Dec 31, 2008
I have a problem with conecting to the network - Di351
Posted on Jun 16, 2011
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
Minolta DI-151 trouble code c0500
Sir/Mam Power off the machine. Wait ten seconds then holding down the Stop/Cancel button power on the machine. Clear the code then power off the machine. Wait 10 seconds and power on. If the code comes back you need to look for a new fusing unit (Hot Part) DO not reset the fuser cold catch on fire. That would ruin a perfectly good day!:).
Jan 19, 2015 | Minolta Office Equipment & Supplies
How I Can Solve the Code C-0540
May 18, 2014 | Minolta DI-2010F Copier
Code c0500
C0500 is a warm-up error on those little machines. Try holding the stop button while switching on, that should reset the code. It sometimes happen if it's kinda cold, or when the power dips. If the code comes back, you'll have to replace the fuser unit.
Oct 18, 2013 | Konica Minolta bizhub 161f All-In-One...
How to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
Apr 04, 2012 | Minolta DiALTA Di183 Copier
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Oct 30, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
2,486 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
