Question about Minolta magicolor 2200 DeskLaser Printer
Print problem half my print is faded help!
  • gordon thorburn May 01, 2007
    it is a laser printer it has toners all of which are full
My printer prints faded copies, I have changed all toner cartridges, transfer belt unit etc but still copies are faded. It flashed a reference to something to do with a toner rack but I'm unable to get this this error message again.
Posted on Jun 16, 2008
    Problem Solver:
  • 14 Answers
Have you tried replacing the ink cartridge?
Posted on May 01, 2007
  • Ryan Santy
    Ryan Santy May 01, 2007
    Let me know exactly what problems you are having
Why do print jobs print out normal, faded, or color (for an all black job) randomly?
I would suggest using the printers self head cleaning as it sounds like the heads need cleaning
Mar 03, 2016 | HP LaserJet CP3505dn Printer
Canon selphy 710 printing only bottom half of photo. how to correct this?
Hiya Jeannie it sounds like you may have overwinded your ink sheet as that makes it impossible to print to all the paper....hope that helps.
Mar 08, 2015 | Canon SELPHY CP710 Dye Sublimation Printer...
It prints only half a page.... how can i fix that???
Does the print fade out or is the printed page complete, just cropped down? If it is fading out then it is the cartridges running dry, or refilled using the incorrect ink. If it is printing the entire document, just smaller, then under printer properties you can set the page size. (control panel - printers and faxes - right click your printer and select printing preferences) I hope this helps Regards GM
Apr 13, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP Deskjet printer 6940 clearly prints only top half of a page. The lower half fades and some lines fade completely. Many thanks for your help!
This problem is mainly due to driver corruption
1. Reinstall the driver or scan for viruses and remove it.
2. Remove all temp files from the drive.
3. Try removing corruption in OS or reload OS.
4. Try connecting to another system and take print out.
5. Chipset on the printer may be having problem, get it serviced.
Sep 05, 2010 | HP Deskjet 6940 InkJet Printer
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
Poor black print quality - printing is light and faded - toner is over half full - any ideas to make it print darker?
Hi... When you are going to print, do visit the properties of the printer first. Make sure you have the 'print in grayscale' off. Hope this helps...
Feb 03, 2010 | HP Laserjet CM 1312NFI Color Printer
Info Print 1352 one half faded other half normal print.
You require a replacement transfer roller, if you remove the toner cartridge and look in the printer, you will see a roller which sits underneath the toner cartridge, this is what you need to replace
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
Won't print but few lines til black fades out
It pretty much sounds to me like you have "outdated" or old cartridges. Are you using the photo setting to print photos? Before you purchase more expensive cartridges do a head cleaning! Good luck.
Dec 16, 2008 | Dell 924 All-in-One InkJet Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Minolta magicolor 2200 DeskLaser Printer Logo
305 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
