Question about Canon FAXPHONE L80 Laser
I just changed over to one phone line and need to now use my fax
And phone lines together. I changed the function to answering and need to know what line I put the cable from the phone into. The L or the phone symbol.
Thanks,Gayle
    Genius:
  • 2,120 Answers
Phone symbol. The line port is for the telephone from the wall jack.
Posted on Jan 01, 2009
When a fax is coming through my machines says failed to connect, what is the problem?
hello sorry we got disconnected but please try this
Based on what I read in the Dell manual I would say the answering machine needs to pick up the line first so the number of rings to answer for the answering machine needs to be less than the rings for the printer (if you set the answer machine to pick on on the second ring set the printer for 3 rings).
Basically this looks like it works similar to other phone line sharing devices, if the manual is correct when the answer machine picks up the printer/fax is supposed to listen to the line, originating fax machines send what is called a CNG tone.
Looks like the machine listens for this tone, if it sees it then it is supposed to cut off the answer machine and complete its fax function, if the tone is not present the Dell should let the answer machine work normally.
From working with phone line sharing devices I have seen most problems occur in the home where people have a single line coming in and they tap off of that line and run jacks to all the rooms in the house.
This creates a problem, when you plug phones or answer machines orfax machines or modems or anything else these devices all have a Ringer Equivalency Number associated with them, the phone company also limites the number of bells (ringer equivalency) on the line.
If the phone company supports 3 bells for example and you connect 2 devices that have a ringer equivalnecy number of 3 that is 6 bells and something is not going to work correctly.
If you can make the answering machine work by itself and you can make the fax feature on the printer work by itself and the problem only shows up when they are connected together then I would think you have either exceeded the number of bells for your line, or Dell has an issue with their feature.
I would suggest as a test if you have in fact tapped off the telephone company line, unplug all of the other phones in the house and just conenct the printer and answer mchine as Dell suggests and see what happens, if it works then you have to decide what phone or phones you are willing to leave unplugged.
Dec 31, 2009 | Dell Photo 964 All-In-One InkJet Printer
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
I can't fax in our out...Don't know about set up
The fax phone line goes to LINE Port
Answering machine goes to TEL Port
Jun 19, 2009 | HP 1040 Plain Paper Inkjet Fax
My incoming call always jump into fax line
Change the fax to answer on the fifth ring or more. Check that the settings are not on 'fax only'. You can have the answer machine pick up on the third ring, just have the fax answer two rings later.
May 01, 2009 | Lands Phones
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
How do we hook up a computer, phone, answering machine, etc.
Not that I know of.....:
Set up a switch close to your desk.. so you can plug in the Fax if you need it.
Sorri.
Feb 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
I have the 5510series four in one. I need to know how to get the fax machine functioning correctly.
Hook a dedicated ANALOG phone line to to the LINE port on your machine.
Sharing a line with an answering machine or whatever makes for big problems.
Aug 27, 2008 | Office Equipment & Supplies
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Canon FAXPHONE L80 Laser Logo
51 people viewed this question
old marine
old marine
