Question about Panasonic DMR-EH55 DVD Recorder/HDD Recorder
Formatted hardrive after virus now windows says there is problem
Xp goes thru the process of loading and windows acts lie it's going to start,then,the blue page that says:a problem has been detected and windows has shut down.....Technical info
Stop:oxoooooo7B[0xF78AA528,0xc0000034,0x00000000,0x00000000
All this started when I got a virus and tried everything to get rid of it and finally formatting the hardrive ands reinstalling XP.I can not get to my desk top only Bios.What can I do to solve this problem?Would a new hardrive solve it?HELP!!!
  • 6,487 Answers
You need to run again the XP installation CD and better if you format and partition the hard drive when you do that....
Posted on Dec 31, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a new harddrive would work but it is not necessary. A few ides to consider:
  • did you re-partition the hard drive before formatting?
  • partition, reformat the harddrive using a 2nd PC using an HD to USB adapter;
  • remove the memory and clean the little gold pins using a hard pencil eraser;
  • set the CMOS/BIOS to default all.
Good luck and Thank you for using FixYa. Happy New Year.
  • 177 Answers
Hello and welcome to FixYa!,
You will need to re-install Windows XP again because it is a corrupted file in Windows causing this. I this does not solve it, a new HDD is the way to go!
Hope it solves your problems -P3NGYJ03
    Genius:
  • 2,035 Answers
Hey remove the hard disk and check if the bios comes when you power it on , if yes then a new hard disk will solve the problem...
Good luck...
I am loading windows xp pro and it goes thru the instaltion till it goes to resart after restart it says there is no hard drive. i have run the rom iag, and it checks the hardrive oassin in all tests. how...
get a copy of xp pro service pack 2,or borrow dell xp cd of someone it comes with integrated drivers and installs all the way through,or disable sata in bios and give it a go worked for me
Apr 28, 2011 | IBM eServer xSeries 346
Will not load windows
Did you format the hardrives?How much ram is in the unit?Why are you reinstalling windows (virus,slow)?
Feb 23, 2008 | MSI MS-1022 Notebook
I have a HP Compaq Evo D51S and when every time I turn it on it displays a message saying that Windows did not start successfully. It appears that it is stuck on a loop, it goes through the normal...
You have removed any system file or driver from your PC or your system have many of viruses. Start windows in safe mode by clicking F10 while booting. Transfer your files from C drive to other drives or in removable drive. Get windows recovery disk and repair your windows xp. This also formates your C drive. Next time, load a licenced antivirus and do not make any changes in C drive.
Jul 24, 2010 | HP Compaq EVO D51S Intel Desktop PC -...
Hi I purchase an Iomega External Hard Drive 500 gb and I am using it in PC format however, when I connect the hard drive it gives me an error when I try to format it. I tried Windows vista home Basic,...
ur harddrive couldnot be formatted probably due to the infection of virus.
try this use window xp and connect ur hard drive open task manager by Pressing CTRL + ALT + DELETE
click on the process tab a list of all the processes going on will come,there u will find a process named explorer.exe
right click on it and select end process tree click yes
after that click on applications tab and click new task
enter explorer.exe on textbox and click ok.
now dont open ur external hardrive ,open mycomputer then quickly format ur hard drive.
Mar 31, 2010 | Iomega 33089 250 GB Hard Drive
Windows xp start to load the it logs me off and goes back to the password screen
You have a major virus, my son had this, too. Format C: and reinstall Windows.
Oct 21, 2009 | Toshiba Satellite A105 Notebook
Yahoo messenger takes awhile to load up when I turn my pc on
1. Click on start if in Windows XP or the window Globe in the left hand bottom corner in Vista.
2. In Windows XP Click on Run or Vista click on the empty white box
3. Type msconfig
4. Disable all start-up programs. Dont uncheck your anti virus and other programs like yahoo which you want at start up.
5. Hit 'OK' and restart.
This process will clearly speed up your system
Jun 11, 2009 | Dell Microsoft Windows XP Home Edition
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
Power issues in toshiba s1800-911
Sounds like you have a problem with your power adapter, battery and or charge port ... I would suggest you let the unit "charge" overnight and try again.
Dec 22, 2008 | Toshiba Satellite A100-S8111TD Notebook
Latitude d600
Dave,
At this point the virus, and it was a virus no doubt, has done irreparable damage to the operating system, and possible the hard drive. You will need an operating system disc, no way around that. Once you have the disc, then you will need to reformat the hard drive using the full NTFS format, not the quick format, to ensure total deletion of the virus, and install a new operating system. If the hard drive won't format or if you have any issues during or after the install, then the hard drive has or is failing and will need replaced. If you need any futher asststance with this just ask.
Aug 29, 2008 | Dell Latitude D600 Notebook
Panasonic DMR-EH55 DVD Recorder/HDD Recorder Logo
187 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
