Question about Toshiba Satellite Pro L300 Notebook
Xp on my laptop
I have satelite l300 and i instaled xp on it. to do that i had tochange SATA options in bios from ACHI to Compatibility NOW SHOULD IRETURN THE OPTION BACK TO ACHI thanks
    Master:
  • 413 Answers
Does the computer still work? there is an old saying. If it ain't broke don't fix it. If the computer still works and boots and you can access all your drives just leave the settings just the way they are. Next thing you know you will change them back and nothing will work anymore.
Posted on Dec 30, 2008
I cant get into bios anymore on my toshiba after trying to install winxp
This problem is common with the L300 series as well as others. It's related to the fact Vista was pre-installed. Has to do with partitioning.
What you have to do is power on the Laptop and then press F2 to get into the BIOS menu. Then scroll down to the SATA option and change it from ACHI to Compatibility then exit saving your changes (F10) and then reboot your Laptop from the XP Operating System disk.
It will now let you install Windows XP or any other Operating System.
http://en.kioskea.net/forum/affich-24383-install-xp-on-toshiba-laptop
Apr 13, 2014 | Toshiba Satellite Pro L300 Notebook
Ibm thinkpad a31p hard drive not found
Thi sis an issue about the hard disk itself .. depending on how was formatted.. or the way was connected. you need to go to bios settings and select the hard disk in the devices .. and if there is an ahci function on . you have to disable it . cause without driver will not see the hard disk .. This is nto an issue if you install a windows 7 but for widows xp .. to work and to use it in this way ..(with the sata raid or sata achi ..) you need to run a 3rd party driver when installing the operation system .. or ....
the quick way .. go to bios by pressing F2 on start .. and in there ..disable teh raid or achi for the hard disk (must be in the ide/sata feature.. where you see the devices for ide.. you have a sata .. setting feature too .. Just select it ..and let it run in compatible mode or non raid . or disable achi ..or sata as ide or native .. depending on the BIOS edition it may refer to the same thing in different ways .. The idea is to disable any function for the hard disk that might require a driver to be installed in order to work ..
after that will boot just right if you have an os on it .. or will be needed another installing from a live disk ..(boot-able disk )
Also check the hard disk options ..and see that some have a second setting for a usb ..and remove it and leave the hdd 0 as primary ) ..This is not the boot priority .. but the actual device ..
]Anyway if you set what I said .. and make a factory default before.. (set it to the factory settings first and after that remove the achi or raid settings ..and save with F10 ) ..and will work .
try it and let me know how it worked out..
Jan 29, 2012 | IBM ThinkPad A31 Notebook
Blue screen upon instal of xp
Are you installing it on laptop?? If it is, try check your BIOS settings on the SATA mode option if available.. usually it is either ACHI or IDE. try to change it and try to install your xp again.
Nov 28, 2011 | Microsoft Windows XP Home Edition English...
When i install the xp cd in my hcl b23 C2D laptop, the problem shown like this. setup did not find any hard disk installed in your computer how to slove?
remove bottom screws from laptop labels with 3 stacked disks.
remove and inspect hdd for damage and possible defects
reinstall firmly and replace cover and screws.
If problem persits, replace HDD
May 13, 2011 | Microsoft Windows XP Professional
Is it posible to set t5he bios to ACHI mode ?
yes ..if it supports it ..usually for a new hdd drive it will not support it cause it will need a achi driver ..and this should be added as a 3rd party by pressing F6 when it asks for xp ..and by browsing for it in the other operation systems..
I guess if you install it as Sata as ide ...(selected in bios ) and after that install the raid and achi driver and go back to bios and change it back ..it will get it ..In the worse case ..you do not have the correct driver and it will say there is no hdd plugged or give you memory error with a blue screen
Jan 18, 2011 | Acer TravelMate 243LC Notebook
MY Compaq Presario CQ40-330TU doesnot installing XP software
Hi
You need to have xp cd with sata disk driver support.
You can make xp with sata driver verymuch easily by downloading sata driver from intel site or other site and merging with xp cd.
Inorder to merge xp with sata driver you need to use the nlite software whcih can be downloaded from .http://www.nliteos.com/
For guide for creating xp with sata use this link http://www.nliteos.com/guide/
For sata driver u can use this link http://www.zyxware.com/articles/2008/10/07/compaq-presario-cq40-108tu-laptop-drivers-for-windows-xp evenethogh it is different model sata driver will be same and it will support for this model also
Mar 01, 2010 | Computers & Internet
Where can i find sata driver for XP?
there are 2 way to solve this problem,
1. change ACHI mode to IDE in BIOS setting
2. Make a XP installation CD with SATA RAID dirver yourself.
googd luck!
Jan 30, 2009 | Computers & Internet
Dear Sir I'm unable to install the Windows Xp in my new laptop i think this problem is with sata HDD so can i download the drivers and install in my laptop
check in bios settings the sata hard disk detect or not.if not detect then u cant install. Reset your bios settings to defaults settings then save and exit.
also check your sata option in bios is enable.try in both situation sata enable and then try sata disable.
Dec 27, 2008 | Compaq Presario Notebook
Toshiba Satellite Pro L300 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
