Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
When I plug it in, the light fades on/off.
I can not see the files.
I CAN see "u3 system" in 'my computer'
The launcher no longer loads.
It did this rather suddenly and recently.
Have not heard from Sandisk, yet.
I tried it in different usb ports and on different machines.
It has always popped up[and loaded until now.
All pc's run at least Windows xp, sp2.
  • 3 more comments
  • buttlook Dec 30, 2008
    If not, can the files be recovered?
    Why would it work fine one day, then do this the next?
    Thanks everyone.
    I will try these thing later and post.
    If you " yank the drive out and do not use the "safely remove hardware" steps when unplugging a USB drive", would it affect the drive, therefore affecting any pc you put it on?
  • buttlook Dec 31, 2008
    Here's what is was.
    My cd-rw driver was either corrupt or conflicted with the driver to the flash drive.
    I decided to either uninstall both, then restart/reinstall.
    Do a Windows 'System restore' as far back as I can (to a time with both were working).
    I did a system restore first.
    I disabled any autorun software on the flash drive so that I would just show up under 'My computer' as a drive, not a menu.
    I did a check disk with error check on the flash drive.
    I ran for a while.
    So far, all appears to be well.
    Thanks again all.
  • 37 Answers
Yes this is a easy fix. First try the USB drive in another computer you have never been too. IF it still doesnt work then you need to goto your main computer., then, reboot with USB out. Place USB drive into a 2.0 USB port, usually on front of newer computers, then wait for about a minute. IF the PC still doesnt recognize the drive, then, RIGHT click on the "MY COMPUTER" logo, then scroll down to "MANAGE",
This will open COMPUTER MANAGEMENT> not click on anything other then what i tell you EXACTLY TO DO.
then carefully click on "Disk Management" on the bottom left tree box. (UNDER STORAGE HEADING).
This should open several boxes on the right side of the box showing your hard drive and other storage devices on your system, and LIST them in the upper box under the "VOLUME" heading.
Then on that VOLUME drive that shows your USB Drive, RIGHT CLICK on it one time. Scroll down to Change Drive Letters and PATHS. THen goto CHANGE button and select a letter you have never used on your PC before like the letter "Z" or "Y". then click OK and close everything.
THen go back to my computer like normal and your drive should appear normal and you should be able to access the drive.
If this doesnt work and you can still see the USB drive, you may need to reformat the USB drive as something may have corrupted the files? This is unlikely but only the last resort.
Let me know how it goes.
Thanks, Mark
Posted on Dec 30, 2008
  • Mark S
    Mark S Dec 30, 2008
    THis happens if you just yank the drive out and do not use the "safely remove hardware" steps when unplugging a USB drive.
The fading light usually means that the drive is standing by (re: not being accessed - waiting to be needed). Does it ever blink quickly as though it IS being accessed? Perhaps when first plugged in?
There is a trick for when Windows systematically has problems allocating a drive letter for explorer:
Right click on My Computer icon and select Manage.
Go to the disk management icon in the Manage window that pops up. It should list all of the available drives as blue bars showing their capacities. Here you can right click on the usb drive (8GB) allocation and click "explore" or "assign new drive letter" or something to that effect.
If there is no sign of an 8GB allocation in the management window on all of the computers you try it on then there is likely a hardware problem with the drive.
I have a Sandisk 8GB cruzer. When I insert it into port the U3 yellow box doesn't come up so I can't set a password. What do I do?
There is a known problem with the U3 software and Windows 7. Are you running Win 7?
Sandisk has upgraded and compatible software available here:
Good Luck, Mikeywaf
Feb 28, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I used the Sandisk cruzer to backup files fron Microsoft XP. Trying to download to my new computer with Windows 7 I get the message that the data is not compatible. Is this a driver problem? What do I need...
You will need to down load the latest version of the U3 launcher @ Hope it helps, to be safe I will however suggest another backup to a XP computer, just to be safe. Good Luck.
Jan 04, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk 8gb cruzer filling itself up???
see if this happens on other computers. If on other computers you have malware on the device itself. If only on one computer then the computer has a malware or configuration problem. Maybe temp files are set to go to path that the usb stick gets when it's inserted. Identify the source of the issue then solve. stick vs machine
Nov 08, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Nov 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Micro 8GB cruzer
Save all your files on your computer before doing this.
Uninstall U3 from settings on launchpad.
Format your USB. Do not Quick format.
Reinstall U3: (only works with Sandisk)
Drag your files into the USB. No more problems!
If anymore problems, reply!
Hope this helps!
Nicholas CHUM
Apr 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
It was working before computer had to reboot
download and install the firmware/driver for the device at
May 31, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
354 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
