Question about Canon PowerShot SD600 Digital Camera
Pictures are too bright when shooting outdoors in sunlight
The camera has suddenly started taking outdoor pictures poorly- they are very bright. Switching from manual to automatic mode makes no difference- still too bright, only a few faint images of dark objects in the view are visible. I thought it might be a stuck iris but in movie mode everything looks fine... so this would indicate that maybe the iris is OK. Any help or suggestions would be appreciated
  • 4 more comments
  • Mark Rowland May 04, 2007
    This unfortunately did not solve the problem.
  • puddleracer Nov 19, 2007
    I just started having the identical problem with this camera. I tried everything but outdoor shots come out just about entirely white. Tried restoring to default settings but didn't help.
  • Floger Mar 03, 2008
    All photos are bright white. I've tried everything to fix but no avail. Is it a settings issue?
  • dbrad Mar 22, 2008
    I have the same problem with a Konica Dimage 530. It will take pictures indoors in low light with no flash. Outside pictures will be totaly white. The video mode works fine outside. I have tried every possible adjustment with the camera in manual mode. Nothing helps!
  • malanis21 Jun 25, 2008
    I have the same problem with sd600, video is is fine outdoors and pics are ok indoors but outside they are completely bright.
    I've tried the manual settings and no success. Is there a firware update available for this or something?
  • ubaidbutt Jul 24, 2008
    my camera fell down and I have almost the same problem but I see some vertical lines as well.
    movie function is preserved.
I went to a repair place and I was told that something is wrong with the light reader inside and thta it would cost 139, since the camera is 199 it make no sense doing it.
Posted on Nov 03, 2008
    Problem Solver:
  • 14 Answers
Have you tried changing your settings manually to outdoor? Or adjusted the aperture? You can usually find the aperture settings under the menu button. If not, try adjusting to outdoor conditions and disabling flash. And also, lower your white balance a good bit.
Posted on May 01, 2007
My canon camera pictures are very bright
You can usually change the brightness settings or theres somtimes an option that reduces brightness when outdoors in the sun and vise versa
Nov 29, 2011 | Canon PowerShot A470 Digital Camera
My sanyo vpc-s670r digital camera has a blurred shot. how can i fix this problem? i also clean the lens still blurred especially when shotting outdoor.
You must take pictures gently. Blur picture may occur if you move during capturing a picture. Or your hand move too fast after taking a picture. Try to stay still for two or three second after push the capture button.
Blur picture when shooting outdoor can be caused by too much light. Don't forget to set your camera in outdoor or panorama mode, and turn of the flash light if you think its too bright.
Hope this help and RATE please !
Jan 16, 2011 | Sanyo VPC-S670 Digital Camera
Fail to take outdoor picture
There is a known "bug" in the earlier S1000 models. You would benefit from a firmware upgrade which is available as a download from Fuji's website. The Canadian site is www.fujifilm.ca . Just look for support and firmware downloads. You can find out there which firmware version is in your camera, and the upgrades, with what they correct.
Feb 16, 2009 | Fuji FinePix S1000FD Digital Camera
Outdoors pictures too bright
I think your ISO setting is very high or is in default.
Please shift it 100 whent you thaking outdoor snaps in daylight or normal indoor light. It will help you to produce a better photograph.
Best wishes.
Nov 30, 2008 | Canon PowerShot A420 Digital Camera
SUDDEN TROUBLES
this problem may happen due to sticky shutters. when a camera is left non operative for a long time sometimes the the shutter gets stuck due to some sticks substance between the blades. BUT you specified thet it's not taking OUTDOOR PICTURES that means that it is working fine indoors ??? That's confusing..
Feb 26, 2008 | Fuji FinePix F10 Digital Camera
Brightness problem
My outdoor pictures are a bright white out,What can I do to resolve this?
Feb 25, 2008 | Casio Exilim EX-Z110 Digital Camera
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
Nov 27, 2007 | Canon PowerShot A430 Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Mar 30, 2007 | Casio Exilim EX-S600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
574 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
