Question about HP Photosmart C6180 All-In-One InkJet Printer
Paper Jam after printing labels
Subsequently, papers jam and or are crumpled on one corner, indicating there still may be something on the roller or small paper stuck where the manufacturer has made it impossible for the consumer to remove...am concerned about removing screws and trying myself without some directions.
    Novelist:
  • 59 Answers
Hi blslstraws,
Sorry to hear about your problem. First, nothing else should get damaged by frequent jams - it's just a pain in the neck. But you should be able to get any remaining paper out and any adhesive glue off the rollers and feed mechanism.
Note that if the printer is still under warranty, your disassembling it may void the warranty if it is detected by anyone else, so make you sure you put everything back where you found it! :-)
First, unplug the unit - we don't want any risk of shock. Put it on a large flat surface (if you don't have an empty table, use a hard floor). Now, go ahead and open the unit up. Remove any screws you think might get you to the roller in question, but place them in a formation that will help you remember where they go (I don't know the insides of the C6180 very well, so I can't tell you which ones to remove). Try using tweezers to remove any visible bits of paper. If the adhesive glue remains on the roller, use an alcohol swab (or a paper towel dipped in rubbing alcohol) to clean it (it will dry by itself in a few seconds).
If this doesn't work, then you may have no choice but to take the unit to be serviced. Let's hope it doesn't come to that.
Please let me know if I can be of any further assistance.
Posted on Dec 30, 2008
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
It crumples the paper up as well
This can be caused from one or more of the following:
1) Paper can go bad if not stored flat or for too long a time,
2) Could be a prior jam not cleared completely
3) Residue on roller(s) or damaged roller(s)
4) misaligned paper tray
5) Broken/Damaged component(s)
Sep 15, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer Jammed
If you unplug the machine when the printhead is out of the corner, you can shine a light in and see where the crumpled paper is, usually on the right side where the cleaning assembly is.
Aug 12, 2009 | Brother MFC-5840CN All-In-One InkJet...
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP ALL IN ONE PRINTER
Follow these steps to clear paper jam
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Jun 19, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
