Question about Sony KV-36FS100 36" TV
Help Hi.I this tv that i can see only in the left side good image but 90% of the picture is withou luminance.Thanks
Measure HT voltage for video drivers(i.e +185v). It will be less than normal,because of the filter capacitor faulty,Normally the value will be 22mfd/250v.Otherwise you can try any Mfd of 250v. Try and reply.
Posted on May 02, 2007
Horizontal lines on LG TV
I hate to give you bad news but about 90% of the time horizontal lines come from a bad panel and if that's the case the set isn't worth fixing as a panel costs hundreds of dollars
Mar 24, 2018 | LG Televison & Video
Tv on no picture
The Power to the video/luminance is missing or The pc video/luminance board is defective needs repair.The Power supply Module provides the voltage to the video/Luminance board.
Nov 03, 2012 | Pioneer PDP-506XDE 50 in. Plasma TV
Convergence is bad on left side...good on right.....where convergence is good the picture is great
Re-solder convergence output ICs pins and nearby big resistors that might solve your tv picture problem and if that does not help then replace both convergence output ICs to fix the problem.
Convergence output ICs would be available in local repair parts shop or google it.
Thanks.
Feb 25, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
My t.v. picture was coming i ghost shade why?
If you are using antennae check the direction. If this is a cable input , then with a DVD , if all these show a ghost image, then the convergence of the TV section must be checked. Possible fault in the picture processing -( Y amp luminance)can lead to ghost images.
Jan 29, 2011 | Televison & Video
Imagen negativa
Hello
Negative image is due to the absence of Luminance signal in picture. You are now seeing only the chrominace part of it. It will be surely due to the Chroma Luminance Juncle Ic fault. You just open your TV, find the chroma luminance jungle Ic, resolder it out from the board, go for a same type and number. Replacing it wil resolve your problem. You must have good concept of soldering and desoldering, as this is a quiet complex job, which may need as far as 68 soldering points, very close to each other, and have the chance to get shorted between. Ok
Nov 13, 2010 | Sanyo DS20930 20" TV
Display rotated 90° to the left. I don't remember doing anything in particular that might have caused this, there are a number of buttons (5) on the right hand-side of the screen that I might have...
To restore the display to the original upright position, kindly press these three key together on your PC keyboard :
CTRL, ALT , UP arrow key (See attached image)
Hope this helps. Thanks for using FixYa.
Aug 30, 2010 | LG Flatron L1919S LCD Monitor
I have a Broksonic Model # CCVG-1440 TV/DVD. When I try to use the TV or the DVD everything except the picture is fine. I even have clear text for setting brightness, contrast etc. but the picture is a...
It sounds like you are missing the luminance drive to the CRT board or the voltage that is provided to amplify the signal. The reason you get a good on screen display is that it is it is fed from aseperate circuit and you get some images because the chrominance signal is still being supplied. The video signal is made up of these two component- luminance and chroma. You usually need an oscilliscope to troubleshoot.
Sep 28, 2009 | Broksonic CTGV-5463TCT TV
Sony kp57hw40 tv blurry image,
Yes, you have a bad convergence Ic--set uses two of them---have someone change both and adjust the set in the Tech menu--if you need more information or help email me etower.766@netzero.net---
Aug 09, 2009 | Sony KP-51WS500 51" Rear Projection...
42" AKAI plasma screen problems
This is a sign of a lack of the luminance signal which may denote a problem with the chromanance signal ariving fast to the screen then the Luminance signal this is video problem. You will need to have a qualified TV technician look at this. You can find one on FixYa.com, or look in your area for one.
Aug 25, 2007 | Akai LCT3201AD 32 in. LCD Television
Weird arch like lines
Hello HollyJ, If possible can you post a picture of the problem, It would help in determining if this is a convergence problem or a pincushion circuit problem. You description while good is a little to general to many possible issues. This sounds like a defection issue but I would not be able to tell unitl I see a picture of the screen, take the picture with a digital camera and the post it to the page using the add image link on the right side of the dialog box. Thank you, Shuttle83,
May 12, 2007 | Philips Magnavox 27MS343S 27" TV
Sony KV-36FS100 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
