Date is September 2003
THANKS!
SOURCE: Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
SOURCE: Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
SOURCE: i have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
SOURCE: Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Date is 9-2003.
Is this digital/need converter box?
