Question about LG Over-the-Range Microwave
Looking for instuctions
I require instructions for an LG microwave type M-S1942ES which i can down load if possible.
Many thanks john
  • loftyj Jan 05, 2009
    All i required was the user guide and yet still i can not seem to down load this simple task without going through the long process of down loading other user systems just to get the basics, never mind .
  • LG Master
  • 9,098 Answers
LG UK manuals here.
Yours shows up in the search.
You'll need to download the free Djvu Viewer to view or print it.
Posted on Jan 02, 2009
Cannot inderstand instuctions. How do you set time to microwave?
Basically find the clock button press it and follow prompts.
Nov 26, 2015 | Microwave Ovens
Looking for complete instructions for Tefal steamer VC100116 Type serie SO4
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Microwave Ovens
How to make pizza in LG MICROWAVE mc7689msr
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers as required.
The Customer Instructions usually contain Cooking Instructions but the web site may have good tips etc.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Nov 08, 2010 | LG Microwave Ovens
I have no manual only model number
If you require an Owner's Manual, you can find one at managemyhome.com. Just type in the model number that you have this question listed under, in the "Manuals" link. and the owner's manual is available in a .pdf (adobe) format that you can download or print for FREE.
Included are the operating instructions, installation instructions, use and care instructions and specifications.
I hope this is what you were looking for.
Oct 21, 2009 | Sharp R-1874 Convection/Microwave Oven
Instruction Manual Needed
The only ref online is http://www.espares.co.uk/parts/microwaves/proline/micro-chef-st22/p/1095/1169/0/542092
Any microwave cooking guide should walk you thru the steps
Jul 28, 2009 | Microwave Ovens
Matag under oven microwave
You'll have to remove and/or modify the frame & existing mounting plate as required, which may require some amount of cutting and drilling too.
The dimensions of the mount that the new one needs will be detailed in your installation instructions.
If for some reason you don't have yours, you can download Maytag (made for Whirlpool by L.G.) owner's manuals and installation instructions here.
Jun 26, 2009 | Microwave Ovens
User manual required for down load
You can download LG UK manuals here.
Dec 31, 2008 | LG Over-the-Range Microwave
MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
Dec 19, 2008 | Microwave Ovens
Change of lamp in LG microwave oven MS-194A
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If you don't have your instructions, please reply back with your brand and model number.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Sep 11, 2008 | LG Microwave Ovens
LG Over-the-Range Microwave Logo
130 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
