Question about Dell Latitude D410 Notebook
CD slot on the side of the docking station?
How do I open it?
    Novelist:
  • 101 Answers
The CD faceplate should have a button which will open the tray (if the power is on) or you should be able to right click on the drive in My Computer and choose the Eject option. If the power is off, you can use a paper clip to open the tray by inserting it into the small hole on the faceplate of the CD drive.
Posted on Dec 30, 2008
    Genius:
  • 1,913 Answers
Check there is lock on it.then unlock it then pull the cd rom.
Usb ports on the ibm docking station not active
Dear rajeshraja42,
Try to run the recovery CD from IBM Docking station, and reconfigure your system by connecting your docking station while you run them.
Or try this:
Connect your docking station to your Laptop then turn the Computer On!
Start>My Computer--- Then right click--- Choose 'Properties'>On the dialog box, ----choose the 'Hardware' Tab> Choose the Device Manager box by click them>Now You are in the DEVICE Manager Box>>>
Run the Scan For Hardware Changes... Then if you find that your docking station appear with Yellow Question Mark Then, right click on it and choose 'Uninstall' from context menu and answer YES! then Run the SCAN for hardware changes for ONE last time, Your System should find your Docking station as part of your system now!
GoodLuck!
Best Regards,
bionic23
Dec 07, 2009 | IBM (250410U) Docking Station for ThinkPad
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
710c cable will not fit in new docking station
Need to buy a new USB to Parallel converter kit (is just a cable and a cd with the installation drivers) cost around $20
Jul 27, 2009 | HP DeskJet 710c InkJet Printer
I have an HP zv5000 Pavilion with HP original Docking station. I it large and doesn't allow me enough length of connection to move my laptop out of the dock. Because of this docking station the monitor...
At this point, you can't find any such cable, since it is outdated. The only thing I could suggest is try to disassemble the dock to remove the cable, the only problem is you would now need desk space to hold the computer...
Nov 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Fix video?
If your video was working fine before then it might be a corrupted file driver of your docking station. No need to worry with your computer because it is not your computer causes the problem. It is your docking station.
You may try reinstalling your docking station software using the cd that came with it.You need to connect your system to your docking station when reinstalling the software. if the issue persist after installing the software. Please check if your docking station still in warranty and check their part replacement policy.
Keep me posted.
thanks.
Oct 16, 2008 | Computers & Internet
USB ports in docking station stopped working suddenly
I was having the same problem - the USB ports seemed to have stopped working so I could not use the mouse, keyboard, or printer, even though the monitors and power could still operate through the docking station. Finally, I just unplugged the docking station for 30 seconds, plugged it back in, and everything resumed working. I was surprised it was that simple, but it's working for the moment.
Aug 27, 2008 | IBM (250410U) Docking Station for ThinkPad
ILive docking station not working properly
hello everyone with this problem I bought a use unit last sunday and it was working ok till next day then not sound not light , I try to push every botton and shut off and on but nothing , after many times I decide to open the boom box , and resoldering all the connections take like 1hour but now the unit works perfect the only thing is the blue light never came on , but cd works fine and radio also the dock for the ipod , is working fine
Aug 06, 2008 | Apple iLive IBCD3816DT Portable 2.1...
Casio Exilim ex-z40 won't down load
Try reinstalling your camera drivers. You need to uninstall it first while docking station is removed. Then reinstall your camera software through the cd that comes with it then try plugging it in again either on the same usb slot or a different usb slot. Then try docking the camera again if theirs any interruptions. Usually if you transfer the docking stations usb cord plug to a different usb slot, the transfer goes haywire. Try transferring to a different usb slot...
If all else fails, get a card reader for your cameras memory card, it is way faster...
Feb 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Dell Latitude D410 Notebook Logo
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
