Question about Kenmore 24872 Top Load Washer
Washer My washer fills with water and thats it. IT won,t wash,spin or drain? The timer moves around but nothing happens? What could be the problem?
    President:
  • 1,294 Answers
Does washer spin without any clothes or water, try 'spin' only. If no, then u might have a loose connection to the motor. After u disconnect from the wall socket, see behind to see if all connections are ok. Do not over-load your machine, it could trip a switch which will stall things. Suggestions...
Posted on May 02, 2007
  • prem mathew May 02, 2007
    Could be a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such as a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the machine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys.
    Did u clean out your outlet filter. If u did.....
    Go to 'troubleshooting' above, click on page 2, look for 'replacing lid switch' Generic Problem. Click there. Catriver is pretty good.
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Have a Maytag washer LAT9635AAE. It fills with water and does not proceed. The timer seems to move the dial around but doesn't engage the washing functions. At first I thought it was simply not...
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 18, 2011 | Maytag Washing Machines
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24872 Top Load Washer Logo
91 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
