SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
SOURCE: Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
SOURCE: Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
SOURCE: my frigidaire top loader fills with water at the
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Thank you for your inquiry, Criss Ard!
From my understanding you are having issues with your Frigidaire laundry center not starting a cycle. You stated that the washer fills with water then locks. It sounds like your timer is not advancing and that could be due to a faulty timer or wiring harness. You may want to perform a reset on your laundry center and you can do that by disconnecting the power cord for roughly ten minutes. If this troubleshooting step does not help resolve your issue you may want to consult with a professional technician for proper repairs. I hope this information is helpful. -Matt
