Question about Linksys Wireless-G WRT54G Router
- Pass Word ?
How to set up the Pass word ? and why i can't found my old Pass word / IP Address ?
    Genius:
  • 1,913 Answers
Reset your router.
it is in back side of router u found reset swich.press it for 5 seconds.then your router reset to factory defaults.
then access with following 2 links 1 is right.
http://192.168.1.1
http://192.168.0.1
thn enter username :"admin"
password is"admin"
or password is blank.
then go to settitngs and set pasword
Posted on Dec 30, 2008
My LG 55LW6500 55 3D HDTVReady LCD won't connect to my NETGEAR R6200 router. The gateway does not pass!
try to manually configure the ip address on your TV settings ... ip address , subnet mask, gateway and dns. refer to the ip address used by your router. :)
Aug 10, 2013 | NA Netgear R6200 802.11ac WiFi Dual...
I cant connect my ds to router
you may need to manually input the ip adress or MAC of router in ds. on on your cpu, you can look up your router and its properties, record ththe type of securtiy or encryption, the pass word, mac address and ip address .
On ds, check to see if ip auto config is enabled or DHCP enabled. if after scanning and connection faills, manually configure wifi settings to mmatch those found earliear on your cpu running the router, entering the mac, ipaddress ect. also be sure you are not to far from the router and the wife switch is turned on somewhere on side of unit so the wifi arcs symbol is iluminated or lit up
Jul 13, 2012 | 2wire Computers & Internet
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Linksys WRT54G2 Wireless Router
How do i change the router network password? what is the ip adress??
The internal, LAN-IP address is normally set to a default, private number. Linksys routers, for example, use 192.168.1.1 for their internal IP address. D-Link and Netgear routers typically use 192.168.0.1. Some US Robotics routers use 192.168.123.254, and some SMC routers use 192.168.2.1. No matter the brand of router, its default internal IP address should be provided in documentation. Administrators often have the option to change this IP address during router setup. In any case, however, the private LAN-IP address remains fixed once set. It can be viewed from the router's administrative console.
The external, WAN-IP address of the router is set when the router connects to the Internet service provider. This address can also be viewed on the router's administrative console. Alternatively, the WAN-IP address can be found by visiting a Web-based IP address lookup service like http://checkip.dyndns.org/ from any computer on the home LAN.
Another way to identify the public IP addresses of routers, involves executing a ping or traceroute command. From inside a home network, the (DOS) command "ping -r 1" will send a message through the home router that will cause its IP address to be displayed. For example, "ping -r 1 www.yahoo.com" should result in a message like the following displayed on the command prompt:
To change router password Open your Internet browser, type the address of the router into the URL address bar, and open it. The address is typically in the form of 192.168.X.X. This is the local network address. Enter the account name and password to open the router setup utility. Navigate through the setup utility until you find the screen that will let you change the password. You will need to enter the old password to change it. Decide on a new password that has good security to a hacker. The best password is more than 8 characters and uses both lower case and upper case letters and numbers. Some will allow you to use special characters also. Do not make the password anything that can be found in a dictionary or any date of significance. Enter the old password in the change password page of the router. When prompted then enter the new password. You will be asked to enter it twice to confirm that the correct password is entered. Immediately, record the new password in some secure location that you can find if you forget it. Confirm the password change on the router page and log off the router. To check the information and that the router has been setup correctly with the new password, open the router address in the browser again and login with the new information. If you are able to login, you have successfully changed the password. Network: Router Ssl Vpn
Dec 25, 2010 | AudioCodes Computers & Internet
How to find ip address
In the my xbox section, go to the very last box that is system settings, then choose network settings and the ip address will be in there.
Jan 27, 2010 | Microsoft Xbox 360 Console
How do i get to my routers home page
you will need to open the router set up page.
connect 1 computer to the router with the cable.
check the Ip address and Default gateway. open the router set up page.
the default gateway is the IP address of the router
click here for more information
Jan 03, 2010 | Zyxel P660HW-D1 Router
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
My ps3 says time up on obtaining ip address
Make sure you are trying to access the right WEP type. I'm using a WPA2, should give you the option
Make sure in the settings and connection list that your address settings are set to automatic. I found that manually setting my internet connection settings so I could put the UPnP as disabled helped me.
or just type 192.168.1.1 or 192.168.0.1 into your web browser and your login for your router will pop up from there you can turn off your wep so it doesn't need a pass.
Thanks.
Jun 13, 2009 | Sony Playstation 3 (PS3) Console
Installing the compaq home internet appliance
does the appliance have a dchp ip address option or auto ip address option. The IP address is used by the wireless network to identify each computer device in your house.
In your wireless router there will be a dhcp server that will lease out ip addresses to devices automatically.
the ip address would be 10.0.0.1 for your router or 192.168.0.1 usually most used ip addresses .
A subnet mask is usually 255.255.255.0 which is also needed.
Go to your desktop computer and go to command prompt . Google your version of windows and command prompt to work out how to do this.
then type in ipconfig
press enter key
note the default gateway address and the desktop's ip address
you may need to enter the default gateway ip address into the fridge also.
if the desktop was 10.0.0.2 subnet mask 255.255.255.0
then make the fridge if manually have to set it
10.0.0.254 subnet mask 255.255.255.0
or 192.168.0.254 subnet mask 255.255.255.0 if it is 192.168.0.2
the first three numbers are called the network address eg 192.168.0
10.0.0
the last number 1 - 254 are individual address part
192.168.0.1 {router uses this 1 usually } to 192.168.0.254
Jan 16, 2018 | Compaq iPAQ Home Internet Appliance IA-1...
Linksys Wireless-G WRT54G Router Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
