Question about Bose Lifestyle SA-1 Amplifier
Primary winding is busted and need to know secondary winding
Bose life style powered speaker system ser.no.LSSP2ZU164657
power amp.ic is TDA 2040.
  • Scott Frye
    Scott Frye May 11, 2010
    HI ...
    Do you need a transformer or TDA module ?
    Thanks
  • 85 Answers
Tda 2040 are a cheap aschips
Posted on Jan 09, 2009
Hi! i have hitach CRT tv has a problem of switching. the power supply is okay but there is no horizontal signal.I have changed the video amp TDA 8362 but still the same problem.
You need to check if you have horizontal drive to the base of the horizontal out transistor. With a scope check the primary and secondary of the horizontal drive transformer to find out where you are losing the drive.
Feb 01, 2015 | Televison & Video
How to change voltage from American standard 120 V to European 220V
This is for a powered speaker? You'll need an "autotransformer" or "step-down transformer" with a 240VAC primary winding and a 120VAC secondary winding. If you try to just use a plug adapter and power that speaker from 240V, you'll destroy it immediately.
Aug 04, 2014 | Yamaha YSP-4000 Main / Stereo Speaker
The unit input voltage is 110 volt and was plugged into 220v outlet. . the input winding is now busted. . i was hoping to know the secondary voltage of the transformer. . i was planning to replace the...
The winding is center tapped. It generates +/-24.5 volts DC. Based on it being a capacitor input filter, we need a peak voltage about 1 volt higher to account for the droop of the capacitor and the .7 volt drop of one silicon diode...
Since we need 25.5 volts peak then we need that divided by 1.414 RMS out of ONE side of the center=tapped secondary... So our secondary voltage is 18 volts either side of center.
You will need a 36 volt center-tapped secondary. Here is one that would work:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=162J36-ND
This has two 18 volt windings that you would connect in series and a dual primary you can set for either 120 or 240 input. About $19 US.
Dec 29, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
Aug 24, 2009 | Bose Wave Radio
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Tips how 2 wind transformer ac -dc .output 12volts. in put 240
your windings of primary to secondary must be in a ratio of 20:1. That is, for a primary with say, 100 windings and input 240 VAC, 5 secondary windings will give you 12 VAC. you need to rectify then regulate if you want 12VDC. Just buy an off the shelf wall-wart.
Jul 13, 2009 | Bose Lifestyle 18 System
No sound on my bose acoustimas wave radio, all other indicators work
I would start to check from the audio amplifier ICs section. Most probably the Audio Amplifier IC faulty but there are many version of Bose Wave radio and therefore couple of Audio amplifier ICs have been used namely TDA 7374, TDA 7375 and more.
Jun 13, 2009 | Bose Wave Radio
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Maxim 32'' monitor style tft lcd tv
Maybe your tv has a busted fuse replace it same value. if a new fuse busted again it means your tv has trouble maybe in primary or secondary power.
Apr 10, 2008 | Televison & Video
Bose Lifestyle SA-1 Amplifier Logo
141 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
