Question about Husqvarna Chain Saw 20" Bar
Spear and jackson chainsaw. runs for a few seconds then stops. needs choke all the time. primer bubble seems to **** back fuel when priming. fuel is clean. saw is 1 month old. plug is fine. saw will not rev. squeezing throttle knocks off choke then saw dies.
  • Anonymous Mar 13, 2014
    have rebuilt the carb. Float valve, gaskets, both diaphrams and circular disk plates over ports.
OK - let's work through this. If you need choke all the time then the mixture is too weak when the choke is off. Putting the choke on literally chokes off the air supply to the engine by lowering a small shutter across the entrance to the carburettor. That means either there is too much air getting to the engine (don't see how!!) or too little fuel. So, how do we get too little fuel? You could check for this as follows;
- before we do anything tricky let's check the obvious things - is there a fresh fuel mix in the tank? Petrol does go off, especially if there is 2 -stroke oil added to it. If it's over a month old from the pump mix up a fresh batch. Is the idle speed set too low so the engine stalls when the choke is knocked off? You can see this screw to one side of the carburettor (you need to remove the top lid in front of the handle on the chain saw, and then remove the air filter to see it). Turn the screw half a turn clockwise to speed the engine up. Be warned - if the engine starts it will run faster than normal and that means the chain may start to spin around. Also - check that the chain brake is off (i.e. the safety lever is pulled backwards, and that the chain is free to move BEFORE you attempt to start)
- is the fuel filter blocked? To get to this, make a wire hook (e.g. thick fuse wire) and gently hook out the fuel filter that's sitting at the bottom of the fuel tank, and take a look at it (be gentle - you can damage the gauze if you are clumsy). Does the gauze look clear? I.e. if you dip it into petrol it will freely run into the filter and of course drain out when you lift it? If not, replace it.
- next stop - are the jets in the carburettor set right? I don't have a service manual for this (and I know the manual says unhelpfully "return for service") but basically you will have seen two holes on the side of the chain saw (below the handle) two small 0.8cm holes; one marked 'L' (for low speed) and the other 'H' (for high). Put a fine flat screwdriver down the L hole and feel for the slot of the low speed jet. Once engaged turn it out half a turn and this will enrich the mixture - if this seems to help and you can start the engine then adjust the L jet in or out until the engine is idling comfortably. If it idles too quickly then you can also turn down the idle screw (see previous paragraph).
- no luck still? Well, it could be fuel pump or a blocked jet in the carburettor but this really is a 'return to the service centre' task!
Posted on Jan 12, 2009
    Sergeant:
    Champion:
  • 239 Answers
Needs adjustmennt on those two screws on the carburator
Posted on Dec 31, 2008
Wher is fuell pump on spear jackson chainsaw
There is no fuel pump it is gravity feed.Make sure gas oil mix is right, check oil tank level, and check filter.if all are ok then you need to adjust the idler and fuel mix screw.
Aug 28, 2014 | Garden
Fuel primer
The primer bulb fills the bowl of the carburetor on initial start-up. Most primer bulbs are depressed 4-6 times. Set the choke at half and either pull the starter cord four times. If it doesn't start, re-prime and take the choke off.
Mar 16, 2014 | Garden
I have a CS4518 Earthquake chainsaw that will crank fine when you pump a little gas to the carb, but stops as soon as it burns the gas. I have replaced all fuel lines, primer bulb , cleaned the carb and...
Hi, OK firstly when you pump the primer bulb the primer bulb pulls fuel from the reservoir and pushes it to the carb then after around six to ten pumps the carb chamber is full and the fuel then goes back to the feservoir. Normally if you have a leak on the fuel line you get air in the priming bulb. Next thing is having primed Put the choke on full and pull the engine over a few times untill you hear it fire. Then depress the throttle and put the choke lever back to normal run position and pull the starter a couple of times untill it starts. Thats a pretty fool proff method on all two stroke machines and I have a few. Hope that is of some help.
Steve
Aug 28, 2013 | Garden
Will run only with choke on
This is fuel starvation ( it is running too lean ) if it has been stood from last year with the same fuel in , the fuel may have gone stale and bloced the jet in the carb, keep priming and starting this may eventualy clear the carb, if not the carb will have to come off and clean through, ley us know if you need help servicing the carb.
Nov 25, 2012 | Garden
Spear and jackson chainsaw will start after priming but will not run. When I prime the saw and use half choke after a few pulls the engine comes to life revs and sounds right. after about 5 seconds the...
Did you check/replace the fuel filter within the tank? Did you re-kit the carburetor when cleaning it? The lower diaphragm fails every so often, but the pumper diaphragm in the upper chamber usually isn't included with a rebuild kit. The lower diaphragm is responsible for maintaining proper fuel quantity to the jets and should be flexible with no holes or tears. There is a very small screen that is located in the passage from the upper chamber to the lower chamber. Check the impulse passage behind the carburetor which delivers pressure pulses to the pumper chamber for plugged holes or torn gaskets around the passage. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies in general to other brands of carburetor. Hope this helps!
Oct 31, 2010 | Garden
Where can I find a lower spring mounting for a Spear and Jackson cs38 chainsaw.
They appear to be well constructed, I wish they were available here.
If purchased at Einhell an OM may be found here:
Spear & Jackson
http://www.einhell-uk.co.uk/index.php?id=2&br=7&sb=11
Please click the "Spares & After Sales" link for parts.
If purchased at ARGOS there is a phone number mid page.
Spear and Jackson UK
http://www.spear-and-jackson.com/en/contact-us
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Where can i get a part for my pull start for my spears jackson chainsaw
see if they have a web site which shows dealers with spares
Jul 05, 2010 | Garden
Runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
Dec 30, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
3,571 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
