Question about Samsung SV3000W VHS VCR
Samsung vcr sv-3000w
I am looking for a parts list for this vcr. The drawer arm is broken and I need a replacement. Also known as the half load position arm. This vcr is not supported any longer by Samsung
techman
  • 3130 Answers
SOURCE: VCR Samsung SV-5000W
You should take off the top cover with the set unplugged and see if there is a main fuse that popped. If there is, put in another fuse,. If that blows, then your going to need to have the power supply in this unit repaired. Good Luck
Posted on Dec 28, 2006
dodgecharger
  • 254 Answers
SOURCE: Faintly blinking power light
This may indicate power supply problems, or perhaps an overload condition, causing the power supply to go into overload protection. If you have a voltmeter, schematic (helpful but not 100% necessary), you could check voltages. You should see at +5 volts, +12 volts, and one or two others. A frequent power supply problem is one or more electrolytic capacitors go wacky, and cause the voltages to be way off, and a non-operational unit. If this is one of the newer low cost rigs, then taking it to a service center isn't cost effective. Toss it and purchase a new one.
Posted on Mar 16, 2007
ginko
  • 19396 Answers
SOURCE: When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Posted on Oct 28, 2008
SOURCE: Samsung SV-5000W VCR. Voltage regulator?
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Posted on Feb 21, 2009
  • 4234 Answers
SOURCE: I have loading problem for My Samsung VCR VX1260.I
That part is the entire loading assembly. It is not likely that you need the entire assembly. I would check in your area for a service shop that works on VCRs. I would suspect a slipping belt as the most likely problem. Belts are relatively cheap. Figure on $4 for a drive/loading belt.
Dan
Posted on Mar 19, 2009
Samsung SV-DVD545 dvd / vcr combi unit cuts off after switch on
i would guess your vcr is not powered off completely preventing the dvd from playing
May 15, 2012 | Televison & Video
My repairer for my SV-DVD3E needs a circuit diagram to complete the repair of my unit.
all diagrams can be found here on this full service manual
http://www.givemefile.net/smanuals/dsrvrc_players/samsung/sv-dvd3e.html
Please vote for me if you found this info useful
Mar 16, 2011 | Samsung SV-DVD3E DVD Player/VCR
Tape got stuck now when trying to eject makes noise then turns off
Good day
Your tape break off inside VCR? Look for broken piece & remove (very carefully)!
RESIST all temptation to touch the drum head! They are very sensitive, & can be ruined easily.
If no broken tape inside, you may have a "broken tire"..a tape spool drive rubber ring.
It's repairable but best bet to find an electronics technician.
The trouble I really suspect is
The loading drawer! There are wee flimsy plastic gears that "pull" the tapes in etc,..they break,...not work after. Need to replace broken parts. Glue won't solve those for long...I've had short-term success.
Mar 11, 2011 | RCA VR622HF VHS VCR
Can't switch on menu or the timer
clean the display and change battery in remote.
Jul 06, 2010 | Samsung SV3000W VHS VCR
The agitator arm is intermittent on my ultimate care II
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Cannot load tape. keeps ejecting tape when trying to load.
Remove the top cover from the VCR. If you have children in the house, look for any object lying in the mechanism. If this is clear, insert a tape slowly into the carriage & watch carefully if the cassette tape flap raises up & allows the tape to be lowered down into the mechanism, if not the flap lever at the side of the carriage may be broken. If the tape does lower into position, look to see if the tape is being pulled out by the guide arms, (normally 2 white poles) one of these may be broken. Check the half loading arm is also not obstructing the tape. If any of these parts are broken a new deck mechanism would be required.
Jul 06, 2009 | Mitsubishi HS-U530 VHS VCR
Jan 04, 2009 | Samsung SV5000W VHS VCR
''place paper in drawer''
Sounds like a paper sensor ; A little black arm that senses paper tray is full, when the tray lifts into position. You might pull the tray and with a flashlight look for any broken parts. I have seen these break when paper jams are removed. This is a Toshiba 2860 correct?
Nov 18, 2008 | Office Equipment & Supplies
Cannot download.please send manual in english
You can download the user manual for Samsung SV-DVD440 here:
Samsung SV-DVD440 User Manual
To get the price of this player, you need to first mention your country.
Thank you
Oct 23, 2008 | Samsung SV-DVD440 DVD Player/VCR
Samsung SV3000W VHS VCR Logo
78 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
