Question about Lexmark Office Equipment & Supplies
My printer is not working
My printer is set up in spanish, the error messege is in spanish . it says Elim.atas.pap y pulse pressed the ck boton dont work
    President:
  • Lexmark Master
  • 990 Answers
Hello sir; Try to press the menu key than go to search labguage thenclick on english,now you can read what is the message said.
Posted on Dec 30, 2008
Scener lock ka messeg ata ha
See your scaner lamp is running or not when it is not running open the glass change the place of the lamp and on the printer then lock the glass and slow tight the sqrue when not working the moter change then working properly the printer
Aug 25, 2013 | Samsung SCX-4216F All-In-One Laser Printer
120.07 service fuser error
An error has occurred in the fuser. Please remove and reseat the fuser. And then reboot the printer. If the error persists, please contact our Technical Support Hotline.
Dec 21, 2012 | Lexmark C748E Laser Printer - Color - 2400...
PAP FD DRVR CIR
My P7005 displays PAP FD DRVR CIR error
Sep 06, 2012 | Printronix Matrix Office Equipment &...
Como resetear dcp165
Instrucciones para reparar el error 46 DCP-165C
Desconectar el enchufe de CA
Conectar de nuevo el cable de CA mientras mantiene pulsado el bot?n "Men?"
y manten?rlo presionado (por 15 seg)
ahora est?n entrando en el modo de mantenimiento aparece en la pantalla LCD "error 46"
Seleccione 8 utilizando el boton de flecha hacia arriba, pulse OK
seleccione 0 y pulsar OK
00:00 00:01 OK (en la pantalla se muestra este mensaje)
Presionar la tecla azul (star black) 25 veces hasta que salga PURGA: xxxxx
Seleccione 2, ok.
Seleccione 7, ok.
Seleccione 8, ok.
Seleccione 3, ok.
El contador de la purga indica ahora: purga: 00000
apaga la impresora, (desconctar el cable CA)
listo para imprimir!!!
May 26, 2011 | Brother DCP 165C Compact Color Inkjet...
I put new harddrive in lenovo x60 while ruuning setting for xp installation .set up loading file then setup is starting window i receive following messege stop : 0x0000007B
I think 7b stopcode is hardware failure. Which means your hard drive is bad.
First I would try getting into your BIOS,(pressing F2 or DELETE or something upon turning your PC on) and finding a setting that says "SATA operation".... i think. You are looking for something that gives you 2 choices... either 'AHCI' or 'ATA'. It may not be called SATA operation, but it will definitely say 'AHCI' and 'ATA' as the two choices. Move the selection to whatever one it is not set on. Then try booting normally, or even re-installing again.
Try that BIOS setting first, that may be the only issue.
Good Luck.
Sep 14, 2009 | Lenovo ThinkPad X60 Tablet PC
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Set the printer to Offline.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press the Forms/1 key.
Press either Arrow key until display shows Test Diag.
Press the CPI/2 key.
Press either Arrow key until display shows Diag Prnt Cal.
Press the LPI/3 key.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Sep 11, 2009 | Tally Line Matrix T6100 Printer
HP PSC 1610 Language reset
Press SETUP until you see 4. PREFERENCES. (Spanish-Preferencias) Press OK.
Press RIGHT ARROW until you see SET LANGUAGE & COUNTRY/REGION. (Spanish-Idioma & Pais) Press OK.
Press LEFT ARROW or RIGHT ARROW until you see ENGLISH. (Spanish-Inglés) Press OK.
When Prompted, press OK.
Press RIGHT ARROW to select the country. Press OK.
When prompted press RIGHT ARROW to select Yes or No. Press OK.
Here is a link to the User Guide. It's on page 93.
PSC1610 User Guide
Nov 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Motorola W375
Vas a presionar el boton de menu (es el boton de en medio de el circulo)> Settings > Initial Setup
> Language
Sigue el order que te mostre arriba y luego eliges spanish
Oct 14, 2008 | Motorola Mobility W375 Cellular Phone
How to reset the ink level monitor on Canon Prixma MP 160
Disconnect the printer's outlet
Hold the Botton of power while connecting to the outlet
Holding down the power button pressed twice the reset button (red circle with a triangle)
Release the power button
The printer takes about 10 seconds into the show vaor numeroco zero.
Pressing + to the value moves from 0 to 1.
When this value to 1, press the button that is on par with reset, this will light up two lamps
One is that of plain papaer and the other of photo paper, at this point is put paper into the printer
Pressing the power button once or twice (it does not matter), the printer will print a proof sheet
When you print this sheet the value in the display returns to zero, leaving it well
Open scan cover (to remove the cartridges but was not removed), with the lid open faith disconnect the power to printer
Remove the cartridge, close the lid and turn on the printer.
Re-positioned and Refill cartridges in the printer and READY.
Mar 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
