Question about Denon AVR-1803 Receiver
No sound! hi all, i have an 1803 and alls been well for 2 years, but now she turns on but no sound?. i notices she does not click any more when you turn the function knob. i have turned up the sound to max and nothing no static, fuses ok, boards look ok, not getting to hot. cant smell any thing? any ideas? regards
    Genius:
  • 1,175 Answers
Hi...
Check to see that ALL the speakers are connected. To the right places too.
Can you get any sound out of the headphone jack?
Make sure there isnt a tape monitor function selected. That will kill all the inputs.
If you still get no output after those checks , I'd say a component or two went good-bye in the power amp section of your unit
Posted on Dec 30, 2008
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Dec 29, 2009 | Denon AVR-1803 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Receiver shuts off when trying to play a dvd in the dvd player.
Just a hunch - what's drawing power from the two convenience outlets on the back of the receiver. They're only rated for 120watts, that is, nothing like a TV.
I doubt this has anything to do with the source you're playing (unless you have it cranked to "11"). If I understand you correctly you said turning the TV on and off causes the problem. There's a clue.
Apr 07, 2009 | Denon AVR-1803 Receiver
Denon AVR 1803 Receiver lost audio
Make sure your receiver is set to either "auto-select" or "digital" rather than "analog" (button on front display).
May 25, 2008 | Denon AVR-1803 Receiver
I need help in connecting my audio video system correctly once and for all.
http://www.retrevo.com/s/Denon-AVR-1803-Receivers-review-manual/id/363bh838/t/1-2/
please have a look in user manual above.
regarding your dvd check for yellow socket named dvd video in----or change your video cable.
Feb 08, 2008 | Denon AVR-1803 Receiver
AVR 1803
There is a thermal non resetable fuse built into transformers primary. There are two leads from a connector that go to Primary of transformer they may be yellow and white leads. If there is no continuity between these two wires Transformer is defective. With Power unplugged pull connector and measure with ohmmeter. Fuse is buried pretty deep inside transformer and some technicians can get it out and replace it but it is not easy.
Jan 17, 2008 | Denon AVR-1803 Receiver
Denon AVR-1803 shuts down
I am a Tech in Michigan and have worked on lots and Lots of Denon AV Receivers. These units have Protection circuits for Overcurrent, Dc Protect, 15v Regulator inbalance, Rail Voltage Inbalance, Low Ac Voltage, Low Standby Voltage and Thermal Protection just to name the ones I remember. My guess is you Probably have either Poor Intermittent solder connections or Amp is not Ventillating Properly. Make sure you leave room above Receiver to Vent and You are using no Less then 6 ohm speaker Impedance per ch. Refer to Speaker Impedance chart on back panel . kstahl65@att.net
Dec 06, 2007 | Denon AVR-1803 Receiver
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Denon AVR-1803 Receiver Logo
78 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
