Question about Mitsubishi VS-60603 60" Rear Projection Television
Need new power cord
I ripped my power cord in two while moving tv. Thinking about sodering peices back together. But would rather have replacement power cord. Can I get one, and then where to get one. Help me out here.
  • 247 Answers
Recommend against soldering the damaged ends together - it's ugly, will never be especially safe, and risks being unreliable too. Have a look at the TV end of the cable. Does it go straight into the TV, or is there a plug that goes into the TV. If there's a plug, just pull it out, take it along to shop that sells TVs and they'll sell you a new one off the shelf. If the cable goes straight into the TV, the solution is just a tiny bit more involved. First, look at the mains plug to check whether it is moulded on, or rewirable. If moulded on, you will need both a new plug, and some flex. If rewireable, you'll only need the flex. Either way, take the cut-off end to Home Depot or somewhere similar and buy something the same shape and size (thickness of the wires is the important thing here). To fit, carefully take the back off the TV and look at how the existing cord was connected and secured before removing it and putting the new one on in exactly the same way. Don't forget to push the wire through the hole in the case (if there is one) before connecting it up. Once the flex is fitted to the TV, fit the plug to the other end. Safety/reliability tip 1 - while the back is off, try not to touch any electrical or electronic components inside the TV other than the power terminals you're supposed to be working on. Saety tip 2 - when renewing a power cord, wire the new cord to the appliance before fitting the plug to the other end of the cord - amazing how many people have helpfully been plugged into the mains in the middle of a job. A.
Posted on May 01, 2007
No power after storm
You will need to replace it. The storm fried your board for sure, there is no fix for that, and a broken board is useless. you can't really put it back together because the entire surface of an electornics board is conducting electricity through it from component to component. If it could be fixed, it will surely cost you more to fix than buy a new one. Sorry to be the bad news bearer but it is shot, you are left with a giant paperweight.
Sep 28, 2012 | Sony KV-32S45 32" TV
What could cause a Philips M # 47PFL3603D/27 to start smoking?
maybe it was hanging out with the wrong crowd... just kidding.. The only way to find out is to open up the tv. Unless the smoke was coming from near the power cord. When you open up the tv, there will probably be some sort of burn mark on the circuit board where a capacitor may have blown. If this is the case (and provided that the circuit board wasn't damaged too badly, you can get a sodering gun, remove the blown capacitor(s) and see if you can find replacements at your local electronics store and then soder it back in. If not, you might need a whole new circuit board.
Mar 15, 2011 | Televison & Video
I replaced the 4 capcitors on the panel and the TV
Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Put the old IP board back.Tries it again should work,if u didn't not burn anything in the Tuner signal board. Keep me in touch how it turn out!
Mar 05, 2010 | Samsung LN-S4051D 40 in. LCD Television
Tv will not turn on. I bought a new power cord
open the back cover and check the fuse inside, it may be broken. Replace it with the same rating as specified in PCB board.
Nov 21, 2009 | Televison & Video
How do you get the last piece covering the rip cord spool off?
It is not a rip cord, please do not use as a parachute, It is a pull cord. My quess would be the remaining part is snapped into place. Trying pushing the side walls towards the center or away.
Sep 11, 2009 | Briggs & Stratton Pressure Washer...
Antenna/Cable Connector partially ripped... Hi, everybody. Does anyone know how to fix a ripped antenna/cable connection? Thanks for the help. My TV Model is a Daewoo DTQ-13P3FC 13" TV for more details....
The cheapest way i can think of is open the tv and solder the ripped peice back on. That should work. If not you can go to radio shack and buy a new peice for it and install it by soldering the connections back on. Hope I could help.
Wayne
Jun 26, 2009 | Daewoo DTQ-13P3FC 13" TV
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
